Mac Pro 2009-2012 Optical Drive Replacement
  1. Mac Pro 2009-2012 Optical Drive Replacement, Remove Side Panel: step 1, image 1 of 2 Mac Pro 2009-2012 Optical Drive Replacement, Remove Side Panel: step 1, image 2 of 2
    • Lift up the latch
    • Remove the Side panel
    • The hard drives and optical drives are locked in place when the latch is down!
  2. Mac Pro 2009-2012 Optical Drive Replacement, The remove the optical drive carrier: step 2, image 1 of 1
    • Pull out halfway
    • Disconnect the cable(s)
2 other people completed this guide.
Ben Capehart
7,414 Reputation
18 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
2 Comments
After adding the drive, the computer does not recognize it. If I swap the cables, the other drive is recognized. Is there a software configuration that I need to make?
wmhoover - Reply
Did you check the cable that won't work for debris?
Ben Capehart -
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 90
All Time: 2,994
