Mac mini (2024) Bottom Cover Replacement
  1. Mac mini (2024) Bottom Cover Replacement, Before you begin: step 1, image 1 of 2 Mac mini (2024) Bottom Cover Replacement, Before you begin: step 1, image 2 of 2
    • Fully shut down your Mac mini and unplug all cables from it.
    • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
  2. Mac mini (2024) Bottom Cover Replacement, Create a gap: step 2, image 1 of 3 Mac mini (2024) Bottom Cover Replacement, Create a gap: step 2, image 2 of 3 Mac mini (2024) Bottom Cover Replacement, Create a gap: step 2, image 3 of 3
    • Using the Jimmy or other metal tools during this step could scratch the aluminum chassis; however, it's the simplest way to perform this step. Follow the alternate instructions to avoid scratching the aluminum.
    • Insert a Jimmy into the gap between the bottom cover and the chassis.
    • Pry up the bottom cover to create a gap.
    • Alternatively, you can insert the point of a spudger into one of the plastic vent holes and pry up to create a gap big enough to insert an opening pick into.
    • Keep the Jimmy inserted under the bottom cover.
  3. Mac mini (2024) Bottom Cover Replacement, Insert an opening pick: step 3, image 1 of 3 Mac mini (2024) Bottom Cover Replacement, Insert an opening pick: step 3, image 2 of 3 Mac mini (2024) Bottom Cover Replacement, Insert an opening pick: step 3, image 3 of 3
    • Insert an opening pick into the gap created by the Jimmy.
    • Remove the Jimmy.
  4. Mac mini (2024) Bottom Cover Replacement, Release the pins: step 4, image 1 of 3 Mac mini (2024) Bottom Cover Replacement, Release the pins: step 4, image 2 of 3 Mac mini (2024) Bottom Cover Replacement, Release the pins: step 4, image 3 of 3
    • Slide the opening pick along the bottom cover until you feel it snag on a pin.
    • There are four pins total—one at each corner of the bottom cover.
    • Twist the pick to lift the pin out of its slot.
  5. Mac mini (2024) Bottom Cover Replacement: step 5, image 1 of 3 Mac mini (2024) Bottom Cover Replacement: step 5, image 2 of 3 Mac mini (2024) Bottom Cover Replacement: step 5, image 3 of 3
    • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining pins.
    • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
    • During reassembly, press along the perimeter of the bottom until you hear and feel all four pins click back into place.
  6. Mac mini (2024) Bottom Cover Replacement: step 6, image 1 of 2 Mac mini (2024) Bottom Cover Replacement: step 6, image 2 of 2
    • Don't remove the bottom cover, as it's still connected to the Mac mini with a cable.
    • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
  7. Mac mini (2024) Bottom Cover Replacement, Disconnect the power button: step 7, image 1 of 2 Mac mini (2024) Bottom Cover Replacement, Disconnect the power button: step 7, image 2 of 2
    • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
    • To disconnect the cable and remove the bottom cover, follow the next two steps.
    • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
    • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
  8. Mac mini (2024) Bottom Cover Replacement, Remove the bottom cover: step 8, image 1 of 1
    • Remove the bottom cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
3 other people completed this guide.
Alex Diaz-Kokaisl
215,624 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
3 Guide Comments
I ripped the crimps off of my power cable because I was pulling out instead of up. Is a new power button cable available for sale somewhere?
Adam Davenport - Reply
@alexdk I created a draft update to the guide with some text with an easier way to open this without potentially marring the aluminum with the Jimmy.
Can you take a look and maybe reword it and give it a test yourself using just a pair of normal spudgers, one in a vent slot to gently lift the edge and one to pry close to the "pins" next to the edge alignment plastic clips (which is a misnomer because they are only for alignment and don't clip anything, only the pins hold things together)?
You can always determine the correct orientation to pry near the pins because they are on the "ends" of the mac mini text, aka left and right as you are reading the words.
dragon788 - Reply
Hello!
Thank you for the suggestions! I tried out the double spudger technique, and it worked somewhat well. I had to really dig the tip of a spudger into the vent, which will have varying mileage for people with dull tips. It was also difficult to get a good enough angle so I could pry up on the edge of the Mac Mini without holding it down with another hand. With that said, I'll incorporate it as alternative procedure for people who want to avoid marring the aluminum (because you're 100% right it will probably happen). I'll make that clear.
Alex Diaz-Kokaisl -
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 262
All Time: 4,163
