Introduction
Use this guide to replace the speaker in your Mac mini (2024).
This guide was written with a baseline M4 Mac mini. Although the internals for the M4 Pro version are slightly different, the disassembly procedure is the same.
Fully shut down your Mac mini and unplug all cables from it.
Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
Insert a Jimmy into the gap between the bottom cover and the chassis.
Pry up the bottom cover to create a gap.
Keep the Jimmy inserted under the bottom cover.
Insert an opening pick into the gap created by the Jimmy.
Remove the Jimmy.
Slide the opening pick along the bottom cover until you feel it snag on a clip.
Twist the pick to lift the clip out of its slot.
Grip the power button cable close to the head and pull it away from its socket to disconnect it.
Tool used on this step:FixMat$36.95
Use a T5 Torx screwdriver to remove the twelve screws securing the inner plate:
Eight 3.4 mm‑long screws
Four 2.4 mm‑long screws
Insert the point of a spudger into one of the clips' slots on the inner plate.
Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
Use one hand to secure the wireless module during this step.
Use a Torx Plus 5IP screwdriver to remove the four 2.5 mm‑long screws securing the wireless module cover.
Insert the point of a spudger under one of the short edges of the wireless module press connector.
Pry up to disconnect the wireless module.
If you're following this guide to clean your fan, this is a good time to do so.
Remove the four screws securing the fan:
Two 2.4 mm‑long Torx Plus 3IP screws
Two 7.9 mm‑long Torx Plus 5IP screws
Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
Let the fan rest on the chassis and heat sink.
Use a Torx Plus 5IP screwdriver to remove the three screws securing the speaker:
Two 4.1 mm‑long screws
One 3.7 mm‑long screw
Grip the speaker cable close to the head and pull it away from its socket to disconnect it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
