Mac mini Late 2018 Disassembly
  1. Mac mini Late 2018 Disassembly, Out of the box: step 1, image 1 of 2 Mac mini Late 2018 Disassembly, Out of the box: step 1, image 2 of 2
    • So here it is, exactly the same form factor as the previous Mac mini, but now in Space Gray
  2. Mac mini Late 2018 Disassembly, Lets flip it over: step 2, image 1 of 3 Mac mini Late 2018 Disassembly, Lets flip it over: step 2, image 2 of 3 Mac mini Late 2018 Disassembly, Lets flip it over: step 2, image 3 of 3
    • Once flipped over, a familiar black cover is revealed.
    • Pry open the lid to release it from the three large screws
    • The lid had a soft foam inside to dampen the vibrations of the beefed up fan
  3. Mac mini Late 2018 Disassembly, Take off the metal cover: step 3, image 1 of 2 Mac mini Late 2018 Disassembly, Take off the metal cover: step 3, image 2 of 2
    • The lid is secured with the same TR6 screws as the 2014 model
  4. Mac mini Late 2018 Disassembly, Reveal the innards: step 4, image 1 of 2 Mac mini Late 2018 Disassembly, Reveal the innards: step 4, image 2 of 2
    • The antenna cable is very short, so watch out; rotate the cover to reveal the internals
  5. Mac mini Late 2018 Disassembly, Antenna cable: step 5, image 1 of 2 Mac mini Late 2018 Disassembly, Antenna cable: step 5, image 2 of 2
    • The antenna cable is held down with a little TX6 screw
    • It has a tiny washer to make sure no stress is applied to the cable
  6. Mac mini Late 2018 Disassembly, Take off the fan: step 6, image 1 of 3 Mac mini Late 2018 Disassembly, Take off the fan: step 6, image 2 of 3 Mac mini Late 2018 Disassembly, Take off the fan: step 6, image 3 of 3
    • The fan has four identical TX6 screws holding it down
    • The screws go trough a rubber tube to reduce vibration
  7. Mac mini Late 2018 Disassembly, Take the fan out: step 7, image 1 of 3 Mac mini Late 2018 Disassembly, Take the fan out: step 7, image 2 of 3 Mac mini Late 2018 Disassembly, Take the fan out: step 7, image 3 of 3
    • Underneath the fan the connector pops off easilly
    • The fan feels solid. Much better than previous models
  8. Mac mini Late 2018 Disassembly, Next, the motherboard: step 8, image 1 of 3 Mac mini Late 2018 Disassembly, Next, the motherboard: step 8, image 2 of 3 Mac mini Late 2018 Disassembly, Next, the motherboard: step 8, image 3 of 3
    • Now, lets take out the motherboard
    • Massive (for the mini) TX10 screws secure the motherboard to the chassis
  9. Mac mini Late 2018 Disassembly, Unplug some wires: step 9, image 1 of 2 Mac mini Late 2018 Disassembly, Unplug some wires: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • The power supply can be unplugged by as many wires as possible between your iFixit tweezers and pull upwards
    • Also take off the tiny power led connector
  10. Mac mini Late 2018 Disassembly, Motherboard out: step 10, image 1 of 2 Mac mini Late 2018 Disassembly, Motherboard out: step 10, image 2 of 2
    • Slide the motherboard out by gently applying pressure to the heatsink
  11. Mac mini Late 2018 Disassembly, Details on the design: step 11, image 1 of 3 Mac mini Late 2018 Disassembly, Details on the design: step 11, image 2 of 3 Mac mini Late 2018 Disassembly, Details on the design: step 11, image 3 of 3
    • Some interesting design choices made here. A full size CMOS battery
    • The wifi wiring runs underneath the large speaker
    • The power button is attached to a ultra flat cable that runs in an arc along the heatsink
  12. Mac mini Late 2018 Disassembly, Motherboard underside: step 12, image 1 of 3 Mac mini Late 2018 Disassembly, Motherboard underside: step 12, image 2 of 3 Mac mini Late 2018 Disassembly, Motherboard underside: step 12, image 3 of 3
    • We flip over the motherboard to see a massive amount of tiny components
    • Also some familiar pieces of foam all over the place
  13. Mac mini Late 2018 Disassembly, Memory cover: step 13, image 1 of 3 Mac mini Late 2018 Disassembly, Memory cover: step 13, image 2 of 3 Mac mini Late 2018 Disassembly, Memory cover: step 13, image 3 of 3
    • But now what we are all here for. The RAM
    • Four TX5 screws holt it down
  14. Mac mini Late 2018 Disassembly, Slide off the cover: step 14, image 1 of 3 Mac mini Late 2018 Disassembly, Slide off the cover: step 14, image 2 of 3 Mac mini Late 2018 Disassembly, Slide off the cover: step 14, image 3 of 3
    • The memory cover slides off at an angle
  15. Mac mini Late 2018 Disassembly, Rubber spacers: step 15, image 1 of 2 Mac mini Late 2018 Disassembly, Rubber spacers: step 15, image 2 of 2
    • These rubber parts will be a pain to put back on later.
    • There are tiny pieces of rubber in it that need to slide into the metal clips holding the memory in place
  16. Mac mini Late 2018 Disassembly, Memory out: step 16, image 1 of 3 Mac mini Late 2018 Disassembly, Memory out: step 16, image 2 of 3 Mac mini Late 2018 Disassembly, Memory out: step 16, image 3 of 3
    • The memory itself sits upside down in its sockets
    • The springs are very strong and will shoot the memory in your face if you're not careful!
  17. Mac mini Late 2018 Disassembly, Power supply connector: step 17, image 1 of 3 Mac mini Late 2018 Disassembly, Power supply connector: step 17, image 2 of 3 Mac mini Late 2018 Disassembly, Power supply connector: step 17, image 3 of 3
    • The power supply is secured in a similar way as with the previous models
    • A little clip has to be removed, and the connector can be rotated
  18. Mac mini Late 2018 Disassembly, Power supply screws: step 18, image 1 of 3 Mac mini Late 2018 Disassembly, Power supply screws: step 18, image 2 of 3 Mac mini Late 2018 Disassembly, Power supply screws: step 18, image 3 of 3
    • The power supply is held down with three TX6 screws
    • They look just like the fan screws, but they appear just a little bit thicker and with longer thread
  19. Mac mini Late 2018 Disassembly, End of the line: step 19, image 1 of 2 Mac mini Late 2018 Disassembly, End of the line: step 19, image 2 of 2
    • After taking out the power supply we are left with an empty shell
    • I really enjoyed taking this mini apart. My verdict is it's much easier than the 2014 model as cables are in a more logical place
14 other people completed this guide.
Wouter de Vries
663 Reputation
1 Guide authored
6 Guide Comments
What happens to the machine if the SSD fails? Will the entire logic board need to be replaced? I have a feeling that the chances of SSD failing would be significantly higher than Ram… So shouldn’t apple make SSD removable as well?
Sam - Reply
Failing SSD means a failing motherboard. In my experience, apple ssd-s are very reliable. Upgradable memory allows you to use a device longer. If you configure it with 16GB today, you might want to max out the memory in the future, once prices go down.
Wouter de Vries -
What about the CPU, is it in a socket or soldered in?
Steve Seg - Reply
I didn’t have the courage to take the heatsink off. So we’ll have to wait for someone who does.
Wouter de Vries -
Mich würde interessieren, wie die CMOS Batterie getauscht wird, bzw. welcher Typ es ist.
Sven Arendsen - Reply
Past 24 Hours: 9
Past 7 Days: 62
Past 30 Days: 352
All Time: 11,861
