Introduction
Use this guide to replace the antenna plate that serves as a mount for the antenna as well as the hard drive.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
When putting back together:
9 other people completed this guide.
2 Comments
when opening my 2011 mac mini, I noticed removing the fan and the cowling is unnecessary to access the antenna plate
The difficult part is putting the grill back in.
