Mac mini Mid 2011 Bottom Cover Replacement
  1. Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Mac mini Mid 2011 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Mid 2011 Bottom Cover Replacement: step 2, image 1 of 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
Finish Line
17 other people completed this guide.
2 Guide Comments
The base plate on my MM has no thumb dimples, no “lock dots”, and it won’t budge. I’ve tried everything short of prying it off—light touch, firm touch, thumbs, palm, nothing has worked. Any suggestions?
Jonathan Royce - Reply
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 51
All Time: 25,331
