Introduction
Use this guide to replace your MacBook Air's AirPort/Bluetooth card.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
11 other people completed this guide.
One Comment
Hi Andrew, thanks for your guide on MacBook Air 11" Late 2010 Airport-Bluetooth Card. I am desperately trying to purchase new cables with female connectors to connect to the Card's male jacks. I ignore the size which is important: I tried MHF 4 too small, MHF 1 too big, so before buying wrong cables again I wonder if you can tell me what size is the Card's jack connection. I thank you for your help in advance.
Max
