MacBook Air 11" Mid 2012 Lower Case Replacement
  1. MacBook Air 11" Mid 2012 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    Tool used on this step:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Buy
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 Lower Case Replacement: step 2, image 1 of 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
6 other people completed this guide.
Andrew Optimus Goldheart
512,672 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,888 Guides authored
1 Guide Comment
Any tips on replacing feet? Thank you. :)
beezermigs - Reply
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 38
All Time: 4,903
