Introduction
Use this guide to replace the lower case on your Late 2020 MacBook Air (M1), or to remove it for further repair.
Tool used on this step:Magnetic Project Mat$19.95
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.3 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
5 other people completed this guide.
One Comment
Hi, I accidentally stripped one of the female thread in the chassis what can I do to fix this? as the screw won't stay in place/screw in
