Introduction
Use this guide to replace the logic board.
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Remove the following five screws securing the battery to the upper case:
Three 6.3 mm T5 Torx screws
Two 2.4 mm T5 Torx screws
Grab the plastic pull tab secured to the display data cable lock and rotate it towards the top side of the computer.
Remove the single 2.85 mm T5 Torx screw securing the SSD to the logic board.
73 other people completed this guide.
18 Comments
great job! thanks a lot
thank you for making it so easy. Great job, you deserve 5 stars *****
Is it possible to swap Macbook air's (2013) logic board for newer model's logic board? (let's say for 2015 macbook air's logic board).
