MacBook Air 13" Mid 2013 Upper Case Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 1, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 1, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: step 1, image 3 of 3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
  2. MacBook Air 13" Mid 2013 Upper Case Replacement: step 2, image 1 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 2, image 2 of 3 MacBook Air 13" Mid 2013 Upper Case Replacement: step 2, image 3 of 3
    • Use the flat end of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
    • If needed, apply a little heat from an iOpener or hairdryer to soften the adhesive.
    • Remove the microphone from the upper case.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 96
