Introduction
Use this guide to replace a broken or cracked screen on your MacBook Air 15" 2024.
Replacing your screen will disable its True Tone functionality.
Unplug all cables and fully power off your MacBook.
Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
Apply a suction handle to the center of the lower case's front edge.
Pull up on the suction handle to create a gap between the lower case and the frame.
Insert an opening pick into the gap.
Slide the pick to the bottom right corner to release the first clip.
Slide the pick around the corner and up the right edge to release the next two clips.
Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
Remove the lower case.
Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
Use a T3 Torx screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
Remove the cover.
Use an opening pick to pry up and disconnect the battery connector.
Use a T3 Torx screwdriver to remove the following screws:
Two 2.6 mm‑long screws securing the left hinge cover
Two 1.5 mm‑long screws securing the speaker cable cover
Use the point of a spudger to pry up and disconnect the right speaker press connector.
Use a T5 Torx screwdriver to remove the two screws securing the top edge of the right speaker:
One 2.7 mm‑long screw
One 5.5 mm‑long screw
Use a T6 Torx screwdriver to remove the 3.5 mm‑long screw securing the bottom edge of the speaker.
Lift the speaker's left edge over the frame and slide it to the left to remove it.
Two 2.6 mm‑long screws securing the right hinge cover
Insert the point of a spudger into one of the right hinge cover's screw holes.
Push the hinge cover away from the back edge to dislodge it.
Remove the hinge cover.
Use the point of a spudger to pry up and disconnect the left speaker press connector.
Use a T5 Torx screwdriver to remove the two screws securing the top edge of the left speaker:
Lift the speaker's right edge over the frame and slide it to the right to remove it.
Use a T3 Torx screwdriver to remove the two 1.5 mm‑long screws securing the antenna cables cover.
Remove the cover.
Insert one arm of a pair of angled tweezers under the metal neck of one of the antenna connectors and lift straight up to disconnect it.
Disconnect the other antenna.
Use a T5 Torx screwdriver to remove the two 5.5 mm‑long screws securing the antenna bar.
Use tweezers or your fingers to remove the foam pad from the cover.
Use a T3 Torx screwdriver to remove the four 1.5 mm‑long screws securing the display and camera cables cover.
Remove the cover.
Use a spudger to pry up and disconnect the display and camera cable press connectors.
Use a T3 Torx screwdriver to remove the two 2.8 mm‑long screws securing the display and camera cables to the frame.
Use the point of a spudger to pry up and disconnect the lid angle sensor from the top left corner of the MacBook.
Use a T8 Torx screwdriver to loosen (not remove) the eight hinge screws.
Fully open your MacBook and gently place it keyboard side down on a table so the screen hangs over the edge.
Support the screen with one hand and use your free hand to remove the eight 4.7 mm‑long T8 Torx screws securing the hinges.
Hold the screen with both hands and lift the hinges out of their recesses to remove the screen.
Make sure the screen hinges are fully open and guide them into their recesses in the frame.
Install and partially tighten the eight hinge screws.
Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
Fully tighten the hinge screws.
