MacBook Air 15" 2024 Thunderbolt Ports Replacement
  1. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Prepare your Macbook Air for disassembly: step 1, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Prepare your Macbook Air for disassembly: step 1, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Prepare your Macbook Air for disassembly: step 1, image 3 of 3
    • Allow your MacBook's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your MacBook.
    • Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
  2. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the lower case: step 2, image 1 of 2 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the lower case: step 2, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
  3. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Insert an opening pick: step 3, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Insert an opening pick: step 3, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Insert an opening pick: step 3, image 3 of 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Release the snapping clips: step 4, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Release the snapping clips: step 4, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Release the snapping clips: step 4, image 3 of 3
    • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. MacBook Air 15" 2024 Thunderbolt Ports Replacement: step 5, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement: step 5, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement: step 5, image 3 of 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Release the sliding tabs: step 6, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Release the sliding tabs: step 6, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Release the sliding tabs: step 6, image 3 of 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the lower case: step 7, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the lower case: step 7, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the lower case: step 7, image 3 of 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the battery connector cover tape: step 8, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the battery connector cover tape: step 8, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the battery connector cover tape: step 8, image 3 of 3
    Buy
    • Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
    • During reassembly, use the leftover adhesive to secure the tape to the cover.
  9. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the battery connector cover: step 9, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the battery connector cover: step 9, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the battery connector cover: step 9, image 3 of 3
    • Use a T3 Torx screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
    • Due to screw variances, you may need to use a T4 Torx instead. Keep this in mind whenever you encounter T3 Torx screws during this repair.
    • Remove the cover.
  10. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the battery: step 10, image 1 of 2 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the battery: step 10, image 2 of 2
    • Use an opening pick to pry up and disconnect the battery connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the speaker cable and hinge covers: step 11, image 1 of 2 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the speaker cable and hinge covers: step 11, image 2 of 2
    • The left speaker will be on your right-hand side when working on the MacBook, as it's laying upside down.
    • Use a T3 Torx screwdriver to remove the following screws:
    • Two 2.6 mm‑long screws securing the right hinge cover
    • Two 1.5 mm‑long screws securing the speaker cable cover
  12. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the covers: step 12, image 1 of 1
    • Remove the speaker cable cover.
  13. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the right hinge cover: step 13, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the right hinge cover: step 13, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the right hinge cover: step 13, image 3 of 3
    • Insert the point of a spudger into one of the right hinge cover's screw holes.
    • Push the hinge cover away from the back edge to dislodge it.
    • Remove the hinge cover.
  14. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the left speaker: step 14, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the left speaker: step 14, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the left speaker: step 14, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the left speaker press connector.
  15. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the left speaker: step 15, image 1 of 2 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the left speaker: step 15, image 2 of 2
    • Use a T5 Torx screwdriver to remove the two screws securing the top edge of the left speaker:
    • One 2.7 mm‑long screw
    • One 5.5 mm‑long screw
    • Use a T6 Torx screwdriver to remove the 3.5 mm‑long screw securing the bottom edge of the speaker.
  16. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the left speaker: step 16, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the left speaker: step 16, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the left speaker: step 16, image 3 of 3
    • Make sure the cable on the top left edge of the speaker doesn't get caught on the logic board, as it may tear.
    • Lift the speaker's right edge over the frame and slide it to the right to remove it.
    • During reassembly, slide the speaker cable under the right edge of the antenna bar assembly before laying the speaker in its recess.
  17. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the right ports cover: step 17, image 1 of 2 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the right ports cover: step 17, image 2 of 2
    Buy
    • A piece of tape on the right edge of the logic board hides the MagSafe and Thunderbolt port connectors cover.
    • Use blunt nose tweezers or your fingers to peel up and remove the tape.
  18. MacBook Air 15" 2024 Thunderbolt Ports Replacement: step 18, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement: step 18, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement: step 18, image 3 of 3
    • Use a T3 Torx screwdriver to remove the three 1.5 mm‑long screws securing the port connectors cover.
    • Remove the cover.
  19. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the Thunderbolt ports: step 19, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the Thunderbolt ports: step 19, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Disconnect the Thunderbolt ports: step 19, image 3 of 3
    • This guide shows how to replace both Thunderbolt ports. If you're replacing a single port, only perform each action on that port.
    • Use a spudger to pry up and disconnect the Thunderbolt port press connectors from the right edge of the logic board.
  20. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Heat the Thunderbolt port cables: step 20, image 1 of 1
    • The Thunderbolt port cables are strongly adhered to the frame.
    • Use a hair dryer to heat the cables and soften the adhesive securing them.
  21. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Separate the cables adhesive: step 21, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Separate the cables adhesive: step 21, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Separate the cables adhesive: step 21, image 3 of 3
    Tesa 61395 Tape
    $2.99
    Buy
    • Slowly peel the Thunderbolt port cables from the frame to separate the adhesive securing them.
    • If your new Thunderbolt ports come with adhesive on the cables, remove the plastic liners and press the cables into place on the frame.
    • If the cables don't have adhesive, use strips of double-sided tape to secure them to the frame.
  22. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the Thunderbolt ports: step 22, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the Thunderbolt ports: step 22, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Unfasten the Thunderbolt ports: step 22, image 3 of 3
    $3.99
    Buy
    • Use a T5 Torx screwdriver to remove the four 3.7 mm‑long screws securing the Thunderbolt ports.
    • During reassembly, the screws will be drawn toward the magnet in the MagSafe port. Use angled tweezers to hold the screws in place while tightening them.
  23. MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the Thunderbolt ports: step 23, image 1 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the Thunderbolt ports: step 23, image 2 of 3 MacBook Air 15" 2024 Thunderbolt Ports Replacement, Remove the Thunderbolt ports: step 23, image 3 of 3
    • Remove the Thunderbolt ports.
Spencer Day
61,610 Reputation
445 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,067 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 73
