MacBook Core 2 Duo Hard Drive Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. MacBook Core 2 Duo Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core 2 Duo Hard Drive Replacement: step 2, image 1 of 1
    • Lift the battery out of the computer.
  3. MacBook Core 2 Duo Hard Drive Replacement, Memory Cover: step 3, image 1 of 1
    • Unscrew the three evenly-spaced Phillips 000 screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
  4. MacBook Core 2 Duo Hard Drive Replacement: step 4, image 1 of 1
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
  5. MacBook Core 2 Duo Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
    • The hard drive goes back into its compartment with the label facing down.
iRobot
1 Reputation
635 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 12
All Time: 7,542
