MacBook Core 2 Duo RAM cover replacement
  1. MacBook Core 2 Duo RAM cover replacement, RAM cover: step 1, image 1 of 1
    • Please remove the three Phillips screws equally spaced on the partition of the battery on the back side of the main unit.
    • Since the screw is fixed to the metal memory cover, there is no worry of losing it.
    • (Translator's Comment) Although I am unable to turn Phillips (Phillips) screws in accordance with the JIS standards sold in Japan, since it does not mean that the shapes are perfectly matched, There is a possibility that it may not be possible to reassemble in the worst case because it is scraped.
    • Drivers for Phillips screws are sold with the notation PHxxx or PH # xxx if going to a home center etc. (x is a number, it is like 000, 00, 0, 1, 2 ... from the smallest tip order). Or you can also purchase it at the iFixit store because it is sold.
  2. MacBook Core 2 Duo RAM cover replacement: step 2, image 1 of 1
    • Pull the L-shaped RAM cover towards you and remove it from the laptop.
To reassemble your device, follow these steps in reverse order.
2 other people completed this guide.
Special thanks to these translators:
jp en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Uhucream
797 Reputation
2 Guides authored
Japanese Translators Member of Japanese Translators
Community
6 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 1,606
