13” & 15” Retina MacBook Pro Glass Bezel Replacement
  1. 13” & 15” Retina MacBook Pro Glass Bezel Replacement, Remove Existing Bezel: step 1, image 1 of 2 13” & 15” Retina MacBook Pro Glass Bezel Replacement, Remove Existing Bezel: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Always power down your device before attempting any repair.
    • This is the only stressful part of the repair but is surprisingly easier than it seems.
    • You need to remove the existing cracked bezel. Use a hairdryer to carefully loosen the adhesive.
    • NOTE: The adhesive is a 4mm strip of double-sided tape and it is only on the top side of the bezel. Be extra careful if you are using a hairdryer or heatgun.
    • You may not need to use heat to loosen the adhesive, I simply used tweezers to pick off bits of glass and was able to slowly take one side off. Then simply running my nail down the other half, the whole bezel came off in one go.
  2. 13” & 15” Retina MacBook Pro Glass Bezel Replacement, Remove Any Left Over Adhesive/Glass: step 2, image 1 of 1
    • Use isopropyl alcohol to remove any leftover adhesive.
    • Make sure there aren't any tiny shards of glass in the small gaps. I recommend using a can of compressed air to remove the shards.
  3. 13” & 15” Retina MacBook Pro Glass Bezel Replacement, Apply The New Bezel: step 3, image 1 of 3 13” & 15” Retina MacBook Pro Glass Bezel Replacement, Apply The New Bezel: step 3, image 2 of 3 13” & 15” Retina MacBook Pro Glass Bezel Replacement, Apply The New Bezel: step 3, image 3 of 3
    • Simply attach the bezel onto your Macbook and use the rubber seal that surrounds the screen to align the bezel.
    • Depending on where you purchased your replacement bezel from, you may not have double-sided tape pre-applied. If not, put a strip of double-sided tape on the top edge of the bezel.
    • The double-sided tape that Apple uses on the bezel is 4mm. I'm not 100% sure but this could make sure the tape doesn't stick to the delicate ribbon cables.
16 other people completed this guide.
Rahul
367 Reputation
1 Guide authored
13 Guide Comments
I followed this guide and when I turned my laptop on I had lines all over the screen. Something behind that bezel pertaining to the screen operation exists and it SHOULD HAVE BEEN WARNED ABOUT!! misleading article!!
M IamSneakySteve - Reply
see my comment below for future reference.
Thomas Goldscheck -
Save yourself the possibility of lines in the LCD, just clean up any excess glass and apply the new bezel over the existing. There is glass under the bezel and cables that even the slightest strain will cause lines. If lined up correctly the second bezel is unnoticeable and does not cause clearance issues.
Thomas Goldscheck - Reply
did it have any issues closing after a while? and did you just apply it with the adhesive mentioned in the article? let me know asap!
Asha Singh -
Anyone else who have done it this way with success? What could potentially be the downsides to this simpler method?
Allan P -
Past 24 Hours: 27
Past 7 Days: 145
Past 30 Days: 671
All Time: 47,552
