MacBook Pro 14" 2021 Screen Replacement
  1. MacBook Pro 14" 2021 Screen Replacement, Unfasten the lower case: step 1, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Unfasten the lower case: step 1, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 14" 2021 Screen Replacement, Unclip the lower case: step 2, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Unclip the lower case: step 2, image 2 of 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 14" 2021 Screen Replacement, Release the right clips: step 3, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Release the right clips: step 3, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Release the right clips: step 3, image 3 of 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 14" 2021 Screen Replacement, Release the left clips: step 4, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Release the left clips: step 4, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Release the left clips: step 4, image 3 of 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 14" 2021 Screen Replacement, Release the sliding clips: step 5, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Release the sliding clips: step 5, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Release the sliding clips: step 5, image 3 of 3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. MacBook Pro 14" 2021 Screen Replacement, Remove the lower case: step 6, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the lower case: step 6, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the lower case: step 6, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery board: step 7, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery board: step 7, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery board: step 7, image 3 of 3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 14" 2021 Screen Replacement: step 8, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 8, image 2 of 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 14" 2021 Screen Replacement: step 9, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 9, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 14" 2021 Screen Replacement, Unfasten the trackpad cable bracket: step 10, image 1 of 1
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 14" 2021 Screen Replacement, Remove the trackpad cable bracket: step 11, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Remove the trackpad cable bracket: step 11, image 2 of 2
    Buy
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 14" 2021 Screen Replacement, Disconnect the trackpad cable: step 12, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Disconnect the trackpad cable: step 12, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 14" 2021 Screen Replacement, Reposition the trackpad cable: step 13, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Reposition the trackpad cable: step 13, image 2 of 2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery board: step 14, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery board: step 14, image 2 of 2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 14" 2021 Screen Replacement: step 15, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 15, image 2 of 2
  16. MacBook Pro 14" 2021 Screen Replacement: step 16, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 16, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 14" 2021 Screen Replacement, Remove the data cable: step 17, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Remove the data cable: step 17, image 2 of 2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 14" 2021 Screen Replacement, Unfasten the battery connector: step 18, image 1 of 1
    • Use a T5 Torx driver to remove the 3.8 mm wide-head screw securing the battery power connector.
  19. MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery connector: step 19, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery connector: step 19, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Disconnect the battery connector: step 19, image 3 of 3
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. MacBook Pro 14" 2021 Screen Replacement, Unfasten the antenna bar's connector bracket: step 20, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Unfasten the antenna bar's connector bracket: step 20, image 2 of 2
    • Use your T3 Torx driver to remove the three 2.1 mm-long screws securing the antenna connector cover and bracket.
  21. MacBook Pro 14" 2021 Screen Replacement: step 21, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 21, image 2 of 2
    Buy
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 14" 2021 Screen Replacement, Disconnect the antenna bar: step 22, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Disconnect the antenna bar: step 22, image 2 of 2
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 14" 2021 Screen Replacement, Unfasten the antenna bar: step 23, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Unfasten the antenna bar: step 23, image 2 of 2
    • Use a T5 Torx screwdriver to remove the six screws securing the antenna bar to the frame:
    • Two 7.5 mm screws
    • Four 3.2 mm screws
    • Use a P2 Pentalobe driver to remove the nine 1.5 mm screws securing the antenna bar to the frame.
    • These screws strip very easily; use constant downward pressure and work slowly when you loosen these.
  24. MacBook Pro 14" 2021 Screen Replacement, Remove the antenna bar: step 24, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Remove the antenna bar: step 24, image 2 of 2
    • Insert the tip of a spudger between the antenna bar and the frame.
    • Pry up with the spudger to separate the antenna bar from the frame.
  25. MacBook Pro 14" 2021 Screen Replacement: step 25, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 25, image 2 of 2
    • Pull the antenna bar straight up and out of the frame to remove it.
  26. MacBook Pro 14" 2021 Screen Replacement, Unfasten the screen cable covers: step 26, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Unfasten the screen cable covers: step 26, image 2 of 2
    • Use a T3 Torx driver to remove the four 2.1 mm screws securing the screen cable covers.
  27. MacBook Pro 14" 2021 Screen Replacement, Remove the screen cable covers: step 27, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Remove the screen cable covers: step 27, image 2 of 2
    Buy
    • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
  28. MacBook Pro 14" 2021 Screen Replacement, Disconnect the screen cables: step 28, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Disconnect the screen cables: step 28, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Disconnect the screen cables: step 28, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the two right-most screen cable press connectors secured to the logic board.
  29. MacBook Pro 14" 2021 Screen Replacement: step 29, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 29, image 2 of 2
    • Repeat the previous step for the left-most press connector.
  30. MacBook Pro 14" 2021 Screen Replacement, Remove the screen cable brackets: step 30, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the screen cable brackets: step 30, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the screen cable brackets: step 30, image 3 of 3
    • Pull up on the back of the screen cable bracket to release the clips securing it to the frame.
    • Remove the screen cable bracket.
    • Repeat for the other screen cable bracket.
  31. MacBook Pro 14" 2021 Screen Replacement: step 31, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 31, image 2 of 2
    • If the two screen cable bracket buffers are removed alongside the brackets, then skip this step.
    • Pull the two screen cable bracket buffers straight up and out of the frame to remove them.
  32. MacBook Pro 14" 2021 Screen Replacement, Unfasten the lid angle sensor cover: step 32, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Unfasten the lid angle sensor cover: step 32, image 2 of 2
    • Use a T3 Torx driver to remove the two 2.1 mm screws securing the lid angle sensor cover near the right hinge.
  33. MacBook Pro 14" 2021 Screen Replacement, Remove the lid angle sensor cover: step 33, image 1 of 1
    • Use tweezers, or your fingers, to remove the lid angle sensor cover.
  34. MacBook Pro 14" 2021 Screen Replacement, Disconnect the lid angle sensor cable: step 34, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Disconnect the lid angle sensor cable: step 34, image 2 of 2
    • Use the flat of a spudger to pry up and disconnect the lid angle sensor's press connector.
  35. MacBook Pro 14" 2021 Screen Replacement, Unfasten the hinge covers: step 35, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Unfasten the hinge covers: step 35, image 2 of 2
    • Use your T5 Torx driver to remove the two 2.5 mm‑long screws securing each hinge cover (four screws in total).
  36. MacBook Pro 14" 2021 Screen Replacement, Remove the hinge covers: step 36, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the hinge covers: step 36, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the hinge covers: step 36, image 3 of 3
    • Use tweezers to pull the hinge covers horizontally away from the hinge to separate it from the frame.
    • Remove the hinge covers.
  37. MacBook Pro 14" 2021 Screen Replacement, Remove some of the hinge screws: step 37, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Remove some of the hinge screws: step 37, image 2 of 2
    • Use a T8 Torx driver to remove two 5.2 mm screws from each hinge (four screws total).
    • Each hinge has a third screw, which you should leave in place for now.
  38. MacBook Pro 14" 2021 Screen Replacement, Protect the MacBook: step 38, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement, Protect the MacBook: step 38, image 2 of 2
    • If you plan to re-use your screen, open it and apply a piece of tape to the glass directly above each hinge. This helps protect the glass from getting scratched in the following three steps.
    • Fully open the screen and stand your MacBook Pro up on one side.
  39. MacBook Pro 14" 2021 Screen Replacement, Remove the remaining screws: step 39, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the remaining screws: step 39, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the remaining screws: step 39, image 3 of 3
    • Use a T8 Torx driver to remove the two remaining 5.2 mm screws (one from each hinge).
    • Remove the topmost screw last, using one hand to steady both halves of the MacBook Pro to make sure they don't separate and fall over unexpectedly.
  40. MacBook Pro 14" 2021 Screen Replacement, Remove the screen: step 40, image 1 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the screen: step 40, image 2 of 3 MacBook Pro 14" 2021 Screen Replacement, Remove the screen: step 40, image 3 of 3
    • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
    • Push both halves of the MacBook Pro together so that the hinges can be lifted clear of their recesses in the chassis.
    • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
  41. MacBook Pro 14" 2021 Screen Replacement: step 41, image 1 of 1
    • Remove the screen.
    • If your replacement display assembly does not have the lid angle sensor pre-installed, you will need to remove the lid angle sensor bracket with a P2 pentalobe screwdriver and transfer it to the new display assembly.
  42. MacBook Pro 14" 2021 Screen Replacement: step 42, image 1 of 2 MacBook Pro 14" 2021 Screen Replacement: step 42, image 2 of 2
    • During reassembly, follow these instructions to align your screen hinges:
    • If you have blue threadlocker, apply a drop to each screw's threads to prevent them from loosening over time.
    • Install the hinge screws without fully tightening them. Center the hinges and check for gaps or rubbing on either side.
    • Fully tighten the hinge screws.
    • If your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
19 other people completed this guide.
Alex Diaz-Kokaisl
215,610 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
27 Guide Comments
Hi where can I buy a replacement screen?
Ryan Li - Reply
Hi Ryan.
We actually sell the screen, a.ka. "display assembly" here. I apologize that the part wasn't linked in the parts section at the top of the page. I will update that for future repairers.
Alex Diaz-Kokaisl -
Thanks! Unfortunately it is out of stock :(
Ryan Li - Reply
Did you completely remove the hinge? Just wondering since I may do a hinge replacement in the future.
Jacko Salakian - Reply
Hi Jacko.
We don't completely remove the hinge with this guide, as it's already attached to the replacement screen.
Alex Diaz-Kokaisl -
Past 24 Hours: 105
Past 7 Days: 763
Past 30 Days: 2,947
All Time: 99,000
