MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement
  1. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Prepare your MacBook for disassembly: step 1, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Prepare your MacBook for disassembly: step 1, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Prepare your MacBook for disassembly: step 1, image 3 of 3
    • Allow your MacBook's battery to drain below 10% before starting this repair. A charged battery may catch fire if damaged during the repair.
    • Fully shut down your MacBook, close the lid, and flip it over. Keep the lid closed until you've physically disconnected the battery.
    • Unplug the MagSafe cable and any accessories connected to your MacBook.
  2. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the lower case: step 2, image 1 of 1
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • Use a P5 pentalobe driver to remove the eight screws securing the lower case:
    • Four 9.2 mm-long screws along the back edge (near the screen hinge)
    • Four 5 mm-long screws along the front edge (near the trackpad)
  3. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Release the sliding clips: step 3, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Release the sliding clips: step 3, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Release the sliding clips: step 3, image 3 of 3
    • Sliding clips along the back edge of the MacBook secure the lower case. In this step, you'll shift the lower case away from the hinges to free it from these clips.
    • Insert the flat end of a spudger between the lower case and the right screen hinge.
    • Lever your spudger against the hinge to push the lower case away from it.
    • Repeat for the left hinge.
  4. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Lower case information: step 4, image 1 of 1
    • After you've released the sliding clips along the back edge, four remaining clips secure the lower case to the frame:
    • Two clips near the cutouts in the frame
    • Two clips near the middle of the lower case
    • As you release the lower case from the frame, you'll hear and feel a distinct "pop" as each of these four clips release.
  5. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Release the right clips: step 5, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Release the right clips: step 5, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Release the right clips: step 5, image 3 of 3
    • Don't insert your tool deeper than 1 cm (a little less than half an inch) near the front of the speaker cutouts to avoid damaging the speakers.
    • Insert the flat end of your spudger into the front of the cutout in the right side of the frame.
    • Slide your spudger toward the back of the cutout and pry up to release the two right-side clips.
    • Repeat for the left-side speaker cutout to release the two left-side clips.
  6. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the lower case: step 6, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the lower case: step 6, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the lower case: step 6, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the trackpad connector cover: step 7, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the trackpad connector cover: step 7, image 2 of 2
    • While your MacBook uses some Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to avoid stripping.
    • Use a T3 Torx driver to remove the two 2.1 mm-long 3IP Torx Plus screws securing the trackpad connector cover.
  8. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the trackpad connector cover: step 8, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the trackpad connector cover: step 8, image 2 of 2
    • Remove the trackpad connector cover.
  9. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the trackpad: step 9, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the trackpad: step 9, image 2 of 2
    • Use the flat end of your spudger to pry up and disconnect the trackpad press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't force it, since a misaligned connector can bend the pins, and cause permanent damage.
  10. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Move the trackpad cable: step 10, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Move the trackpad cable: step 10, image 2 of 2
    • Light adhesive secures the trackpad cable to the battery board.
    • Peel the trackpad cable from the battery board and move it over the front edge of the MacBook.
    • Be careful not to crease or damage the cable.
  11. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Soften the battery data cable adhesive: step 11, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Soften the battery data cable adhesive: step 11, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Soften the battery data cable adhesive: step 11, image 3 of 3
    • The battery data cable is adhered to the battery board and logic board. In the next few steps, you'll disconnect it, separate its adhesive, and remove it.
    • Heat an iOpener and place it on the battery data cable for 30 seconds to soften its adhesive.
    • If you don't have an iOpener, you can use a hair dryer to lightly heat the cable. Be careful not to overheat the battery, as doing so is a fire hazard.
  12. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reveal the battery board ZIF connector: step 12, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reveal the battery board ZIF connector: step 12, image 2 of 2
    Buy
    • Use your tweezers to peel back the tape covering the battery data cable ZIF connector on the battery board.
  13. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the ZIF connector: step 13, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the ZIF connector: step 13, image 2 of 2
    • Use the point of your spudger to flip up the small locking flap on the battery data cable ZIF connector on the battery board.
  14. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the battery board: step 14, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the battery board: step 14, image 2 of 2
    • Use your tweezers to slide the connector straight out of its socket to disconnect it from the battery board.
  15. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reveal the logic board battery data ZIF connector: step 15, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reveal the logic board battery data ZIF connector: step 15, image 2 of 2
    • Use your tweezers to peel back the tape covering the battery data cable ZIF connector on the logic board.
  16. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the ZIF connector: step 16, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the ZIF connector: step 16, image 2 of 2
    • Use the point of your spudger to flip up the small locking flap on the logic board battery data ZIF connector.
  17. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the logic board battery data cable: step 17, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the logic board battery data cable: step 17, image 2 of 2
    • Use your tweezers to grip the neck of the cable and slide it straight out of its socket to disconnect it from the logic board.
  18. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Separate the battery data cable adhesive: step 18, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Separate the battery data cable adhesive: step 18, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Separate the battery data cable adhesive: step 18, image 3 of 3
    • The battery data cable is lightly adhered to the battery board and logic board.
    • Slide the tip of an opening pick between the upper section of the battery data cable and the logic board to separate the adhesive.
    • Slide your pick between the lower section of the cable and the silver wide-head screw to separate the remaining adhesive.
  19. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the battery data cable: step 19, image 1 of 1
    • Remove the battery data cable.
  20. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the battery connector: step 20, image 1 of 1
    • Use a T5 Torx driver to remove the 3.9 mm-long 5IP Torx Plus wide-head screw securing the main battery connector.
  21. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the main power connector: step 21, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the main power connector: step 21, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the main power connector: step 21, image 3 of 3
    • Use the flat end of your spudger to lift the main battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent breaking it.
    • For added safety, place a non-conductive barrier, such as a piece of a playing card, between the connector and board.
  22. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the antenna cables: step 22, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the antenna cables: step 22, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the antenna cables: step 22, image 3 of 3
    • Use your T3 Torx driver to remove the three 2.1 mm-long 3IP Torx Plus screws securing the antenna connector cover and bracket.
    • Remove the cover.
  23. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the antenna bar: step 23, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the antenna bar: step 23, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the antenna bar: step 23, image 3 of 3
    $3.99
    Buy
    • Insert one arm of your angled tweezers under the metal neck of one of the antenna connectors and gently lift up to disconnect it.
    • Lift only on the metal sections of the connectors. Don't lift the cables themselves.
    • Repeat for the other two antenna connectors.
    • To reconnect antenna cables like these, hold each one in place over its socket and press down with the flat end of your spudger until the connector snaps into place.
  24. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the antenna bar: step 24, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the antenna bar: step 24, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the antenna bar: step 24, image 3 of 3
    • Use a P2 pentalobe driver to remove the nine 1.6 mm-long screws securing the antenna bar.
    • During reassembly, don't overtighten these screws—ensure they thread in properly, then tighten only until they're snug.
    • Use your T5 Torx driver to remove the six remaining 5IP Torx Plus screws securing the antenna bar:
    • Four 3.2 mm-long screws
    • Two 7.5 mm-long screws
  25. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the antenna bar: step 25, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the antenna bar: step 25, image 2 of 2
    • Remove the antenna bar.
  26. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the right-side connector covers: step 26, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the right-side connector covers: step 26, image 2 of 2
    • Use your T3 Torx driver to remove the nine 2.1 mm-long 3IP Torx Plus screws securing the four connector covers to the right side of the logic board.
  27. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the right-side connector covers: step 27, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the right-side connector covers: step 27, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the right-side connector covers: step 27, image 3 of 3
    Buy
    • Use tweezers or your fingers to remove the four connector covers from the right side of the logic board.
  28. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the lid angle sensor: step 28, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the lid angle sensor: step 28, image 2 of 2
    • Use the point of your spudger to pry up and disconnect the lid angle sensor press connector.
  29. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the MagSafe port: step 29, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the MagSafe port: step 29, image 2 of 2
    • Use the flat end of your spudger to pry up and disconnect the MagSafe port press connector.
  30. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the USB-C ports: step 30, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the USB-C ports: step 30, image 2 of 2
    • Use the flat end of your spudger to pry up and disconnect the two USB-C port press connectors.
  31. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the headphone jack: step 31, image 1 of 1
    • Use the point of your spudger to pry up and disconnect the headphone jack press connector.
  32. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the Touch ID connector cover: step 32, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the Touch ID connector cover: step 32, image 2 of 2
    • Use your T3 Torx driver to remove the two 2 mm-long 3IP Torx Plus screws securing the touch ID connector cover to the top left corner of the logic board.
  33. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the touch ID connector cover: step 33, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the touch ID connector cover: step 33, image 2 of 2
    • Remove the touch ID connector cover.
  34. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the touch ID connector: step 34, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the touch ID connector: step 34, image 2 of 2
    • Use the point of your spudger to pry up and disconnect the touch ID press connector.
  35. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the microphone: step 35, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the microphone: step 35, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the microphone: step 35, image 3 of 3
    • Use tweezers to peel back the tape covering the microphone ZIF connector to the right of the fan.
    • Use the point of your spudger to flip up the locking flap on the head of the connector.
    • Use your tweezers to grab the neck of the cable and slide it straight out of its socket to disconnect it.
  36. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the left speaker: step 36, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the left speaker: step 36, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the left speaker: step 36, image 3 of 3
    • Peel back the tape covering the left speaker ZIF connector on the right side of the logic board.
    • Flip up the locking flap on the head of the connector.
    • Slide the cable straight out of its socket to disconnect it.
  37. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the fan connector: step 37, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the fan connector: step 37, image 2 of 2
    • The fan cable is adhered to the logic board. To avoid damaging the socket or cable, you'll unlatch the ZIF connector before separating the adhesive.
    • Peel back the tape covering the fan ZIF connector.
    • Flip up the small locking flap on the head of the connector.
  38. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Separate the fan cable adhesive: step 38, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Separate the fan cable adhesive: step 38, image 2 of 2
    • Slide the tip of an opening pick under the fan cable to separate the adhesive securing it to the logic board.
  39. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the fan: step 39, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the fan: step 39, image 2 of 2
    • Slide the fan connector straight out of its socket to disconnect it.
  40. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the right speaker: step 40, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the right speaker: step 40, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the right speaker: step 40, image 3 of 3
    • Peel back the tape covering the right speaker ZIF connector on the left side of the logic board.
  41. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reveal the keyboard connector: step 41, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reveal the keyboard connector: step 41, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reveal the keyboard connector: step 41, image 3 of 3
    • Peel back the tape covering the keyboard connector to the right of the main battery connector.
  42. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the keyboard ZIF connector: step 42, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unlatch the keyboard ZIF connector: step 42, image 2 of 2
    • Use an opening tool or a clean fingernail to flip up the locking flap on the head of the keyboard connector.
  43. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the keyboard: step 43, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the keyboard: step 43, image 2 of 2
    • Slide the keyboard connector straight out of its socket to disconnect it.
  44. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the keyboard backlight: step 44, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the keyboard backlight: step 44, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Disconnect the keyboard backlight: step 44, image 3 of 3
    • Peel back the tape covering the keyboard backlight connector to the right of the keyboard connector.
    • Slide the connector straight out of its socket to disconnect it.
  45. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the logic board: step 45, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the logic board: step 45, image 2 of 2
    • Use a T6 Torx driver to remove the three 6IP Torx Plus screws along the top and left edges:
    • Two 4.6 mm-long screws
    • One 5.6 mm-long screw
    • Use your T5 Torx driver to remove the eight 5IP Torx Plus screws along the right edge, bottom edge, and fan:
    • Two 3.8 mm-long screws with silver screw heads
    • Two 3.7 mm-long screws with small, black screw heads
    • Two 5.1 mm-long screws
    • Two 3.6 mm-long screws along the left edge of the fan
  46. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the logic board: step 46, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the logic board: step 46, image 2 of 2
    • Use your T3 Torx driver to remove the two 3.7 mm-long 3IP Torx Plus screws securing the middle of the logic board.
  47. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Move the cables out of the way: step 47, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Move the cables out of the way: step 47, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Move the cables out of the way: step 47, image 3 of 3
    • Gently fold the right-side cables upright so they don't catch on the logic board in the next steps.
  48. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Peel up the rubber gasket: step 48, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Peel up the rubber gasket: step 48, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Peel up the rubber gasket: step 48, image 3 of 3
    • A rubber gasket lays over the fan and heatsink and is secured with mild adhesive.
    • Slide an opening pick between the fan and the rubber gasket to separate its adhesive.
    • Peel the gasket away from the fan.
    • The gasket is still connected to the heatsink. Leave it in place for now.
  49. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Separate the touch ID sensor cable: step 49, image 1 of 2 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Separate the touch ID sensor cable: step 49, image 2 of 2
    • Insert your opening pick between the left edge of the touch ID sensor cable and the logic board to separate its adhesive.
  50. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Pry up the logic board: step 50, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Pry up the logic board: step 50, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Pry up the logic board: step 50, image 3 of 3
    • Be careful not to snag the logic board on any of the eight cables on the right side of the frame.
    • Insert your spudger between the right edge of the logic board and the frame.
    • Pry up until you can grab the logic board with your fingers.
  51. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Lift the logic board: step 51, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Lift the logic board: step 51, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Lift the logic board: step 51, image 3 of 3
    • Lift the logic board over the fan and shift it down slightly.
    • This helps free the ports along the left side from the frame.
  52. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the logic board: step 52, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the logic board: step 52, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the logic board: step 52, image 3 of 3
    • Pull the logic board to the right to free the ports along the left side from the frame.
    • Remove the logic board.
    • During reassembly, make sure none of the 15 cables become trapped underneath as you lower the logic board into place.
    • Use your spudger—or pieces of tape—to hold the cables out of the way.
  53. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the MagSafe port: step 53, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the MagSafe port: step 53, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Unfasten the MagSafe port: step 53, image 3 of 3
    • Use a T2 Torx driver to loosen the two set screws in the frame that align the MagSafe port.
    • Don't remove these screws. Just loosen them a few turns above the frame.
    • Depending on the condition of your driver, a T3 Torx bit might fit best.
    • Use your T5 Torx driver to remove the two 2.7 mm-long 5IP Torx Plus screws securing the MagSafe port.
    • These screws are non-magnetic—be careful not to lose them.
  54. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the MagSafe port: step 54, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the MagSafe port: step 54, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Remove the MagSafe port: step 54, image 3 of 3
    Buy
    • Use tweezers or your fingers to pull the MagSafe port out of its recess and remove it.
  55. MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reassembly information: step 55, image 1 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reassembly information: step 55, image 2 of 3 MacBook Pro 14" Late 2023 (M3) MagSafe Port Replacement, Reassembly information: step 55, image 3 of 3
    • Follow this step to align and install your MagSafe port.
    • Hold the MagSafe port in its recess and connect your charger to hold it in place while you work.
    • Use your T5 Torx driver to loosely thread in the two 2.7 mm-long screws. Don't fully tighten them yet.
    • Use your T2 Torx driver to fully tighten the set screws to align the MagSafe port.
    • Fully tighten the two Torx Plus 5IP screws.
Clay Eickemeyer
69,485 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,893 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 172
