MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 1, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 1, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Cable Replacement, I/O Board Cable: step 1, image 3 of 3
    • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
    • During reassembly, connect this end first, as it does not flex.
    • In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
Brett Hartt
129,818 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,409 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 7
All Time: 267
