MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement, I/O Board: step 1, image 1 of 2 MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement, I/O Board: step 1, image 2 of 2
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  2. MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement: step 2, image 1 of 3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement: step 2, image 2 of 3 MacBook Pro 15" Retina Display Mid 2012 I/O Board Replacement: step 2, image 3 of 3
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
    • Carefully lift the I/O board and remove it from the lower case.
2 other people completed this guide.
Brett Hartt
129,818 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,409 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 6
All Time: 479
