MacBook Pro 15" Unibody Mid 2012 Feet Replacement
  1. MacBook Pro 15" Unibody Mid 2012 Feet Replacement, Lower Case: step 1, image 1 of 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 2, image 1 of 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2012 Feet Replacement, Feet: step 3, image 1 of 3 MacBook Pro 15" Unibody Mid 2012 Feet Replacement, Feet: step 3, image 2 of 3 MacBook Pro 15" Unibody Mid 2012 Feet Replacement, Feet: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 4, image 1 of 1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 5, image 1 of 1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 6, image 1 of 1
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 7, image 1 of 3 MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 7, image 2 of 3 MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 7, image 3 of 3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 15" Unibody Mid 2012 Feet Replacement: step 8, image 1 of 1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
19 other people completed this guide.
Arthur Shi
257,458 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,892 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 6,229
