MacBook Pro 16" 2021 Lower Case Replacement
  1. MacBook Pro 16" 2021 Lower Case Replacement, Unfasten the lower case: step 1, image 1 of 2 MacBook Pro 16" 2021 Lower Case Replacement, Unfasten the lower case: step 1, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.1 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 16" 2021 Lower Case Replacement, Unclip the lower case: step 2, image 1 of 2 MacBook Pro 16" 2021 Lower Case Replacement, Unclip the lower case: step 2, image 2 of 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 16" 2021 Lower Case Replacement, Release the rear cover's right clips: step 3, image 1 of 3 MacBook Pro 16" 2021 Lower Case Replacement, Release the rear cover's right clips: step 3, image 2 of 3 MacBook Pro 16" 2021 Lower Case Replacement, Release the rear cover's right clips: step 3, image 3 of 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 16" 2021 Lower Case Replacement, Release the rear cover's left clips: step 4, image 1 of 3 MacBook Pro 16" 2021 Lower Case Replacement, Release the rear cover's left clips: step 4, image 2 of 3 MacBook Pro 16" 2021 Lower Case Replacement, Release the rear cover's left clips: step 4, image 3 of 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 16" 2021 Lower Case Replacement: step 5, image 1 of 3 MacBook Pro 16" 2021 Lower Case Replacement: step 5, image 2 of 3 MacBook Pro 16" 2021 Lower Case Replacement: step 5, image 3 of 3
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  6. MacBook Pro 16" 2021 Lower Case Replacement, Remove the lower case: step 6, image 1 of 3 MacBook Pro 16" 2021 Lower Case Replacement, Remove the lower case: step 6, image 2 of 3 MacBook Pro 16" 2021 Lower Case Replacement, Remove the lower case: step 6, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
4 other people completed this guide.
Alex Diaz-Kokaisl
215,837 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
1 Guide Comment
Thank you for this guide. It is incredibly easy to understand and follow.
Ruslan Kurchenko - Reply
Past 24 Hours: 12
Past 7 Days: 76
Past 30 Days: 320
All Time: 15,990
