MacBook Pro 16" 2021 Trackpad Replacement
  1. MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the lower case: step 1, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the lower case: step 1, image 2 of 2
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.1 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 16" 2021 Trackpad Replacement, Unclip the lower case: step 2, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Unclip the lower case: step 2, image 2 of 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 16" 2021 Trackpad Replacement, Release the rear cover's right clips: step 3, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Release the rear cover's right clips: step 3, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Release the rear cover's right clips: step 3, image 3 of 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 16" 2021 Trackpad Replacement, Release the rear cover's left clips: step 4, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Release the rear cover's left clips: step 4, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Release the rear cover's left clips: step 4, image 3 of 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 16" 2021 Trackpad Replacement: step 5, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement: step 5, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement: step 5, image 3 of 3
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  6. MacBook Pro 16" 2021 Trackpad Replacement, Remove the lower case: step 6, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Remove the lower case: step 6, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Remove the lower case: step 6, image 3 of 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  7. MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the battery board: step 7, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the battery board: step 7, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the battery board: step 7, image 3 of 3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 16" 2021 Trackpad Replacement: step 8, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement: step 8, image 2 of 2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 16" 2021 Trackpad Replacement: step 9, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement: step 9, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the trackpad cable bracket: step 10, image 1 of 1
    • Use a T3 Torx driver to remove the two 2.1 mm‑long screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad cable bracket: step 11, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad cable bracket: step 11, image 2 of 2
    Buy
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the trackpad cable: step 12, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the trackpad cable: step 12, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector from the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 16" 2021 Trackpad Replacement, Reposition the trackpad cable: step 13, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Reposition the trackpad cable: step 13, image 2 of 2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the battery board: step 14, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the battery board: step 14, image 2 of 2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 16" 2021 Trackpad Replacement: step 15, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement: step 15, image 2 of 2
  16. MacBook Pro 16" 2021 Trackpad Replacement: step 16, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement: step 16, image 2 of 2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 16" 2021 Trackpad Replacement, Remove the data cable: step 17, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Remove the data cable: step 17, image 2 of 2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the battery connector: step 18, image 1 of 1
    • Use a T5 Torx driver to remove the 3.9 mm pancake screw securing the battery power connector.
  19. MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the battery connector: step 19, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Disconnect the battery connector: step 19, image 2 of 2
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
  20. MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the trackpad: step 20, image 1 of 2 MacBook Pro 16" 2021 Trackpad Replacement, Unfasten the trackpad: step 20, image 2 of 2
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Ten 5 mm screws
    • Three 5.8 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  21. MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: step 21, image 1 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: step 21, image 2 of 3 MacBook Pro 16" 2021 Trackpad Replacement, Remove the trackpad: step 21, image 3 of 3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  22. MacBook Pro 16" 2021 Trackpad Replacement: step 22, image 1 of 1
    • Remove the trackpad assembly.
    • During reassembly:
    • Make sure your new trackpad has a ribbon cable installed. If necessary, transfer the old cable, or install the one your new trackpad came with.
    • Make sure that each of the nine washers are present before you install the trackpad.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 16" 2021 Answers community for help.
5 other people completed this guide.
Alex Diaz-Kokaisl
226,436 Reputation
1,106 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,241 Guides authored
4 Guide Comments
Is there any way to adjust the trackpad button sensitivity? My trackpad seems to be a bit soft/flimsy when sliding my finger on it. I've already tried adjusting the click via the system preferences but it still feels kinda soft in the center of the trackpad. Wondering if there's a hardware fix to it...
Leonardo Rosas - Reply Share
Great guide!
I cleaned my trackpad on a 14" 2021 MBP. Gravy incident so the cleaning had to be through.
Everything is clean and back to normal, but the trackpad clicks are much louder.
Guessing the original glue used to hold trackpad down damped the sound somewhat because my double-sided tape solution doesn't have the same padding.
Not a huge deal, but much prefer the original click sound.
Dale - Reply Share
On a separate note, the gravy may have stained the LED key lighting. It's as clean as I can get it, but I've only cleaned under the keycaps.
The gravy keys are noticeably dimmer.
Suggestions on getting deeper to clean the LEDs?
Dale - Reply Share
Are these steps the same on a 2019 MacBook Pro 16"?
At the moment, I'm still in the troubleshooting stage. My built-in trackpad works perfectly most of the time, but often it'll become sluggish and intermittently unresponsive. For example, when I started searching for troubleshooting tips about 20 minutes ago, the trackpad was as described above out of the gate. After four or five minutes, it started working normally again. Do these symptoms mean I need to replace the trackpad?
rauchman - Reply Share
Past 24 Hours: 12
Past 7 Days: 52
Past 30 Days: 265
All Time: 8,222
