MacBook Pro 17" Models A1151 A1212 A1229 and A1261 RAM Shield Replacement
iRobot
iRobot and 7 other contributors
Last updated on January 25, 2025
5 minutes
Easy
Introduction
Go to step 1
Removing a few screws will remove this part and allow access to your RAM.
Parts
Tools
iFixit earns commission when you buy through these links.
  1. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 RAM Shield Replacement, Battery: step 1, image 1 of 1
    • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
  2. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 RAM Shield Replacement, RAM Shield: step 2, image 1 of 1
    • Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
  3. MacBook Pro 17" Models A1151 A1212 A1229 and A1261 RAM Shield Replacement: step 3, image 1 of 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
9 other people completed this guide.
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 7,950
