MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Upper Case Replacement
Introduction
Go to step 1Changing the top case will also give you a new trackpad.
Parts
Tools
Show more…
Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
Remove the four identical Phillips 3.4 mm screws from the memory door. These screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove. On the A1261 these screws have 4 mm diameter heads rather than the 3 mm heads on the body screws.
