MacBook Pro 17" Unibody fixing noise fan and overheat
  1. MacBook Pro 17" Unibody  fixing noise fan and overheat, Before starting: step 1, image 1 of 1
    • I am using Husky screwdrivers HD 74501 U & HD 74502 Y
  2. MacBook Pro 17" Unibody  fixing noise fan and overheat, Getting ready: step 2, image 1 of 1
    • Turn your MBP upside down
  3. MacBook Pro 17" Unibody  fixing noise fan and overheat, Screws first: step 3, image 1 of 1
    • Remove the screws from the back cover
  4. MacBook Pro 17" Unibody  fixing noise fan and overheat, Open it !: step 4, image 1 of 1
    • Carefully open the back cover.
  5. MacBook Pro 17" Unibody  fixing noise fan and overheat, Dust ? No, thanks !: step 5, image 1 of 1
    • Remove the dust . I am using a vacuum cleaner here with a brush.
  6. MacBook Pro 17" Unibody  fixing noise fan and overheat, Apple warranty: step 6, image 1 of 1
    • Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
    • Keep your Apple warranty and disconnect the battery.
  7. MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: step 7, image 1 of 3 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: step 7, image 2 of 3 MacBook Pro 17" Unibody  fixing noise fan and overheat, Disconnect the fan: step 7, image 3 of 3
    • Disconnect the fan from the mainboard.
  8. MacBook Pro 17" Unibody  fixing noise fan and overheat, Almost there !: step 8, image 1 of 1
    • Remove the 3 screws that fron the fan fixture.
  9. MacBook Pro 17" Unibody  fixing noise fan and overheat, Take a walk on the wild side !: step 9, image 1 of 1
    • Clean the dust with a very soft toilet paper.
  10. MacBook Pro 17" Unibody  fixing noise fan and overheat, Finally!: step 10, image 1 of 1
    • This is what I´ve found inside one fan !
13 other people completed this guide.
LAOMUSIC ARTS
613 Reputation
1 Guide authored
6 Comments
I’d be careful about using a vacuum cleaner on the inside of the computer as it can cause static discharge and zap your components.
pov - Reply
Thanks a lot s
Sanzi Gao - Reply
Sanzi Gao - you are welcome!
LAOMUSIC ARTS - Reply
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Kendall Lui - Reply
Since my 2008 Macbook Pro has been overheating for a while I tried this. Unfortunately everything inside is quite clean: no dust in the fans or heat-sinks.
The fans run quite well , and get going pretty fast as the device heats up. Any other ideas are welcome, This was a GREAT machine and I miss using it.
Eric Hammond - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 9,977
