MacBook Pro 17" Unibody Optical Drive Cable Replacement
  1. MacBook Pro 17" Unibody Optical Drive Cable Replacement, Lower Case: step 1, image 1 of 1
    • Seven 3 mm Phillips screws.
  2. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 2, image 1 of 2 MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 2, image 2 of 2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
  3. MacBook Pro 17" Unibody Optical Drive Cable Replacement, Battery: step 3, image 1 of 3 MacBook Pro 17" Unibody Optical Drive Cable Replacement, Battery: step 3, image 2 of 3 MacBook Pro 17" Unibody Optical Drive Cable Replacement, Battery: step 3, image 3 of 3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
  4. MacBook Pro 17" Unibody Optical Drive Cable Replacement, Optical Drive: step 4, image 1 of 1
    • Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way.
    • Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
  5. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 5, image 1 of 1
    • Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
    • The camera cable socket is very fragile. Do not apply any upward force to this socket, as it may break off the logic board. Pull the camera cable parallel to the face of the logic board.
    • For Late 2011 models, the camera connector plugs straight down into the motherboard—to remove this connector, gently lift it straight up.
  6. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 6, image 1 of 1
    • Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
    • Pull the cable parallel to the face of the optical drive.
  7. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 7, image 1 of 1
    • Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.
  8. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 8, image 1 of 1
    • Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
  9. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 9, image 1 of 2 MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 9, image 2 of 2
    • If present, remove the small piece of EMI foam near the Bluetooth board.
    • De-route the camera cable from the slot molded into the Bluetooth board housing.
  10. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 10, image 1 of 1
    • Use the flat end of a spudger to pry the optical drive connector up and out of its socket on the logic board.
  11. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 11, image 1 of 1
    • Remove the three 3.5 mm Phillips screws securing the optical drive to the upper case.
    • To remove the screw closest to the battery, it may be helpful to use a T6 Torx screwdriver to first remove the upper case bracket directly above it.
  12. MacBook Pro 17" Unibody Optical Drive Cable Replacement: step 12, image 1 of 1
    • Remove the optical drive from the upper case, minding any cables that may get caught.
  13. MacBook Pro 17" Unibody Optical Drive Cable Replacement, Optical Drive Cable: step 13, image 1 of 2 MacBook Pro 17" Unibody Optical Drive Cable Replacement, Optical Drive Cable: step 13, image 2 of 2
    • Grab the optical drive cable by its connector and pull it away from the body of the optical drive.
    • Pulling on anything other than the optical drive connector may damage the optical drive cable.
9 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 11,068
