Introduction
In this guide, you will be able to replace a damaged keyboard on your MacBook with a new keyboard or a backlit one.
Let's Start:
Shut down the Mac and lay it upside-down.
Press the little lever to raise the access door.
Pull the battery straight out of the MacBook using the plastic tab connected to the battery.
Remove the eight screws located on the bottom of the MacBook.
One 3 mm Phillips screw
Three 13.5 mm Phillips screws
Four 3.5 mm Phillips screws
Remove the Phillips screw securing the battery cable cover.
Lift the cover straight from the upper-case.
Use the spudger to pry the battery level indicator straight from the logic board.
Tool used on this step:Tweezers$4.99
Pull the battery cable away from the logic board.
Use the tip of the spudger to lift the keyboard cable retaining flap.
Pull the cable away from its socket to disconnect it. Make sure you lift the retaining flap before pulling the cable or you could damage it.
Disconnect the cable on the right if your Mac has this. This cable is the backlight on the keyboard. Remove it in a similar way as above.
Remove the three screws securing the optical drive.
Pull the Optical Drive out of the upper-case.
Almost done! Insert the new keyboard in your MacBook and follow these steps in reverse order to put your MacBook back together.
