MacBook Unibody Model A1342 Disassembly
Bob McBoberface
Bob McBoberface and one other contributor
Last updated on January 19, 2017
5 - 15 minutes
Easy
In Progress
Community-Contributed Guide
Introduction
Go to step 1
First, we will remove the two 1GB RAM sticks. Then, we will remove the stock 500GB, 5400 RPM HDD.
Parts
Tools
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Show more…
  1. MacBook Unibody Model A1342 Disassembly, Lower Case: step 1, image 1 of 2 MacBook Unibody Model A1342 Disassembly, Lower Case: step 1, image 2 of 2
    • Using a PH00 bit, remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Disassembly, Identify: step 2, image 1 of 1
    • Identify the parts we need to remove. Start with unplugging the battery (circled in red), followed by removing the RAM sticks (circled in orange), and lastly removing the hard drive (circled in green).
  3. MacBook Unibody Model A1342 Disassembly, Unplug Battery: step 3, image 1 of 3 MacBook Unibody Model A1342 Disassembly, Unplug Battery: step 3, image 2 of 3 MacBook Unibody Model A1342 Disassembly, Unplug Battery: step 3, image 3 of 3
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  4. MacBook Unibody Model A1342 Disassembly, Remove RAM: step 4, image 1 of 1
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
  5. MacBook Unibody Model A1342 Disassembly, RAM cont.: step 5, image 1 of 2 MacBook Unibody Model A1342 Disassembly, RAM cont.: step 5, image 2 of 2
    • After the RAM chip has popped up, pull it straight out of its socket.
    • BE SURE TO HANDLE THE RAM STICK BY THE EDGES. DO NOT TOUCH THE CIRCUITRY.
  6. MacBook Unibody Model A1342 Disassembly, Second RAM Stick: step 6, image 1 of 3 MacBook Unibody Model A1342 Disassembly, Second RAM Stick: step 6, image 2 of 3 MacBook Unibody Model A1342 Disassembly, Second RAM Stick: step 6, image 3 of 3
    • Repeat steps 4-5 to remove the second RAM stick.
  7. MacBook Unibody Model A1342 Disassembly, Hard Drive: step 7, image 1 of 1
    • Identify Hard Drive.
  8. MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: step 8, image 1 of 3 MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: step 8, image 2 of 3 MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: step 8, image 3 of 3
    • Using a PH00 bit, remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
    • Lift the retaining bracket out of the upper case.
  9. MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: step 9, image 1 of 1
    • Using PH00 bit, unscrew the 4mm Phillips screw holding down the ribbon attaching the HDD to the motherboard.
  10. MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: step 10, image 1 of 2 MacBook Unibody Model A1342 Disassembly, Hard Drive cont.: step 10, image 2 of 2
    • Using the flat end of a spudger, detach the ribbon from the motherboard.
  11. MacBook Unibody Model A1342 Disassembly, Removed Hard Drive: step 11, image 1 of 3 MacBook Unibody Model A1342 Disassembly, Removed Hard Drive: step 11, image 2 of 3 MacBook Unibody Model A1342 Disassembly, Removed Hard Drive: step 11, image 3 of 3
    • Congrats, you have removed the hard drive!
  12. MacBook Unibody Model A1342 Disassembly, SATA: step 12, image 1 of 3 MacBook Unibody Model A1342 Disassembly, SATA: step 12, image 2 of 3 MacBook Unibody Model A1342 Disassembly, SATA: step 12, image 3 of 3
    • Remove the SATA cable from the hard drive by gently pulling the connector away from the body of the hard drive.
  13. MacBook Unibody Model A1342 Disassembly, Nice Job!: step 13, image 1 of 1
    • To replace all the removed parts, do the aforementioned steps in reverse order.
Bob McBoberface
161 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,338
