Macintosh IIsi Ram Replacement
  1. Macintosh IIsi Ram Replacement, Top Case: step 1, image 1 of 2 Macintosh IIsi Ram Replacement, Top Case: step 1, image 2 of 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Macintosh IIsi Ram Replacement: step 2, image 1 of 3 Macintosh IIsi Ram Replacement: step 2, image 2 of 3 Macintosh IIsi Ram Replacement: step 2, image 3 of 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Macintosh IIsi Ram Replacement, Ram: step 3, image 1 of 3 Macintosh IIsi Ram Replacement, Ram: step 3, image 2 of 3 Macintosh IIsi Ram Replacement, Ram: step 3, image 3 of 3
    • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
    • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
  4. Macintosh IIsi Ram Replacement: step 4, image 1 of 3 Macintosh IIsi Ram Replacement: step 4, image 2 of 3 Macintosh IIsi Ram Replacement: step 4, image 3 of 3
    • 1st Photo: The RAM Module
4 other people completed this guide.
Chris Green
38,200 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
332 Members
1,473 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 2,453
