Macintosh PowerBook 1400 Series Keyboard Replacement
  1. Macintosh PowerBook 1400 Series Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series Keyboard Replacement: step 2, image 1 of 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series Keyboard Replacement: step 3, image 1 of 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series Keyboard Replacement, CD-ROM Drive: step 4, image 1 of 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series Keyboard Replacement: step 5, image 1 of 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series Keyboard Replacement: step 6, image 1 of 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
  7. Macintosh PowerBook 1400 Series Keyboard Replacement, Keyboard: step 7, image 1 of 1
    • Locate the speaker cover.
  8. Macintosh PowerBook 1400 Series Keyboard Replacement: step 8, image 1 of 1
    • Press firmly on each end of the speaker cover and slide it to the left.
  9. Macintosh PowerBook 1400 Series Keyboard Replacement: step 9, image 1 of 1
    • Gently lift the speaker cover to remove it.
  10. Macintosh PowerBook 1400 Series Keyboard Replacement: step 10, image 1 of 1
    • Lift the keyboard up from the back using a spudger(wedge side).
  11. Macintosh PowerBook 1400 Series Keyboard Replacement: step 11, image 1 of 1
    • Gently lift the keyboard until only the ribbon cable remains attached.
  12. Macintosh PowerBook 1400 Series Keyboard Replacement: step 12, image 1 of 1
    • Tilt the keyboard away from the screen.
  13. Macintosh PowerBook 1400 Series Keyboard Replacement: step 13, image 1 of 1
    • Locate the six screws that secure the heatsink.
  14. Macintosh PowerBook 1400 Series Keyboard Replacement: step 14, image 1 of 1
    • Remove the six screws from the heatsink using the Philips #1 screwdriver.
  15. Macintosh PowerBook 1400 Series Keyboard Replacement: step 15, image 1 of 1
    • Lift the heatsink from the side closest to the laptop screen.
  16. Macintosh PowerBook 1400 Series Keyboard Replacement: step 16, image 1 of 1
    • Remove the heatsink.
  17. Macintosh PowerBook 1400 Series Keyboard Replacement: step 17, image 1 of 1
    • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
  18. Macintosh PowerBook 1400 Series Keyboard Replacement: step 18, image 1 of 1
    • Detach the ribbon cable.
  19. Macintosh PowerBook 1400 Series Keyboard Replacement: step 19, image 1 of 1
    • Remove the keyboard.
Sean Bent
41 Reputation
1 Guide authored
Cal Poly, Team 10-39, Forte Spring 2011 Member of Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 9
All Time: 2,506
