Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement
  1. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Outer Casing: step 1, image 1 of 1
    • Flip the guitar over so it is back side up. The battery compartment should be facing up.
    • Use a size J1 head screwdriver to remove the ten 5 mm short screws.
    • Use a J1 screwdriver to remove the four 5 mm long screws on the back of the device.
  2. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: step 2, image 1 of 1
    • Turn the device over so the front of the guitar is facing you.
    • Using a size J1 philips head screwdriver, remove the eleven 5 mm silver screws (circled in red) around the white panel.
  3. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: step 3, image 1 of 1
    • Gently lift the white panel and twist 90 degrees clockwise.
    • Using a size J1 head screwdriver, remove the two 5 mm black screws from underneath the white panel. You should now be able to pull the guitar apart.
  4. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement, Sync Component: step 4, image 1 of 1
    • Remove the two black 5 mm screws (circled in red) from the back of the power button component using a size J1 philips head screwdriver. You can identify this by the code J5-B on the component.
    • Lift the small, rectangular circuit board out and set it aside.
  5. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: step 5, image 1 of 1
    • Locate the sync component hardware. It is a small circuit board that sits sideways with respect to the other circuit boards around it.
    • Remove the two 5mm black screws (circled in red) holding the circuit board in place using a size J1 philips head screwdriver. The component should now slide out vertically.
  6. Mad Catz Rock Band 4 Wireless Fender Sync Component Replacement: step 6, image 1 of 1
    • Follow the wires connected to the sync component back to the main circuit board. Unplug the component from the main circuit board.
2 other people completed this guide.
Hollynn Ricker
451 Reputation
2 Guides authored
USF Tampa, Team 1-1, Cagle Fall 2016 Member of USF Tampa, Team 1-1, Cagle Fall 2016
USFT-CAGLE-F16S1G1
4 Members
6 Guides authored
One Comment
How do I replace the sync wire? Where can I purchase a new sync component?
Ange - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 33
All Time: 2,307
