Mad Catz Street Fighter IV FightPad Circuit Board Replacement
  1. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Rear and Side Case: step 1, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to completely remove the sticker from the rear of controller.
  2. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 2, image 1 of 1
    • Find the seven 8.3 mm Phillips screws on the rear of the controller and remove them.
  3. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 3, image 1 of 2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to separate the rear and front casing by inserting it in-between the two cases.
    • Use the plastic opening tool to pry the two cases apart.
  4. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 4, image 1 of 2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 4, image 2 of 2
    • Remove the two rubber side grips.
  5. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: step 5, image 1 of 2 Mad Catz Street Fighter IV FightPad Circuit Board Replacement, RS-DP-LS Switch: step 5, image 2 of 2
    • Locate RS-DP-LS switch.
    • Pull upwards on the switch to remove it.
  6. Mad Catz Street Fighter IV FightPad Circuit Board Replacement, Circuit Board: step 6, image 1 of 1
    • Locate the four 8.3 mm Phillips screws on the circuit board and remove them.
  7. Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 7, image 1 of 3 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 7, image 2 of 3 Mad Catz Street Fighter IV FightPad Circuit Board Replacement: step 7, image 3 of 3
    • Hold the controller cable at the area just before it meets the controller and slowly lift upwards to slide it out of its plastic slot and remove the circuit board.
    • Be careful with the wires connected to the circuit board itself as they are thin and delicate.
    • When reassembling the controller, make sure that the bottom plastic piece is fully inserted into its slot before replacing the circuit board.
Jefferson Hsu
411 Reputation
3 Guides authored
Cal Poly, Team 1-7, Propen Fall 2012 Member of Cal Poly, Team 1-7, Propen Fall 2012
CPSU-PROPEN-F12S1G7
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,076
