Magellan RoadMate 5120-LMTX Screen Replacement
  1. Magellan RoadMate 5120-LMTX Screen Replacement, Back Cover: step 1, image 1 of 3 Magellan RoadMate 5120-LMTX Screen Replacement, Back Cover: step 1, image 2 of 3 Magellan RoadMate 5120-LMTX Screen Replacement, Back Cover: step 1, image 3 of 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Screen Replacement: step 2, image 1 of 3 Magellan RoadMate 5120-LMTX Screen Replacement: step 2, image 2 of 3 Magellan RoadMate 5120-LMTX Screen Replacement: step 2, image 3 of 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Screen Replacement, Motherboard: step 3, image 1 of 3 Magellan RoadMate 5120-LMTX Screen Replacement, Motherboard: step 3, image 2 of 3 Magellan RoadMate 5120-LMTX Screen Replacement, Motherboard: step 3, image 3 of 3
    • There will be two 5mm Phillips #00 screws that need to be removed from the motherboard.
  4. Magellan RoadMate 5120-LMTX Screen Replacement: step 4, image 1 of 3 Magellan RoadMate 5120-LMTX Screen Replacement: step 4, image 2 of 3 Magellan RoadMate 5120-LMTX Screen Replacement: step 4, image 3 of 3
    • Some devices may have a piece of tape or plastic over the ribbon cable latch. If your device has this, remove it before continuing.
    • Carefully lift the black ribbon cable latch upwards with a spudger or other similar tool.
    • Once the ribbon cable latch is opened, insert the pointed end of the spudger, or other similar tool, underneath the ribbon cable.
    • Slowly pull out the ribbon cable in a straight, flat motion with respect to the latch.
  5. Magellan RoadMate 5120-LMTX Screen Replacement: step 5, image 1 of 2 Magellan RoadMate 5120-LMTX Screen Replacement: step 5, image 2 of 2
    • Be careful not to touch any of the electrical components on the motherboard as damage may ensue.
    • Carefully lift the motherboard out of the plastic housing by the edges while guiding the ribbon cable through the slot.
    • Store the motherboard on a safe non-conductive surface, preferably an anti-static mat.
  6. Magellan RoadMate 5120-LMTX Screen Replacement, Screen: step 6, image 1 of 3 Magellan RoadMate 5120-LMTX Screen Replacement, Screen: step 6, image 2 of 3 Magellan RoadMate 5120-LMTX Screen Replacement, Screen: step 6, image 3 of 3
    • Use a plastic opening tool to release the screen from the tabs.
    • Using too much force can break the tabs.
    • Lift and slide the screen out from the housing.
    • If the screen is cracked, be careful of sharp or loose glass shards.
Chris Blaskowski
370 Reputation
3 Guides authored
IUPUI, Team 4-4, Wilson Fall 2016 Member of IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 379
