Magellan RoadMate 5120-LMTX Speaker Replacement
  1. Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: step 1, image 1 of 3 Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: step 1, image 2 of 3 Magellan RoadMate 5120-LMTX Speaker Replacement, Back Cover: step 1, image 3 of 3
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Magellan RoadMate 5120-LMTX Speaker Replacement: step 2, image 1 of 3 Magellan RoadMate 5120-LMTX Speaker Replacement: step 2, image 2 of 3 Magellan RoadMate 5120-LMTX Speaker Replacement: step 2, image 3 of 3
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
  3. Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: step 3, image 1 of 2 Magellan RoadMate 5120-LMTX Speaker Replacement, Speaker: step 3, image 2 of 2
    • Open the device and remove the tape from the speaker wire using the spudger.
  4. Magellan RoadMate 5120-LMTX Speaker Replacement: step 4, image 1 of 2 Magellan RoadMate 5120-LMTX Speaker Replacement: step 4, image 2 of 2
    • Remove the two 4mm Phillips #00 screws securing the speaker assembly and remove speaker.
Chris Blaskowski
370 Reputation
3 Guides authored
IUPUI, Team 4-4, Wilson Fall 2016 Member of IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 148
