Magellan RoadMate 5236T-LM Back Cover Replacement
  1. Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: step 1, image 1 of 3 Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: step 1, image 2 of 3 Magellan RoadMate 5236T-LM Back Cover Replacement, Back Cover: step 1, image 3 of 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Back Cover Replacement: step 2, image 1 of 3 Magellan RoadMate 5236T-LM Back Cover Replacement: step 2, image 2 of 3 Magellan RoadMate 5236T-LM Back Cover Replacement: step 2, image 3 of 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Back Cover Replacement: step 3, image 1 of 2 Magellan RoadMate 5236T-LM Back Cover Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
Megan Scribner
315 Reputation
2 Guides authored
UMass Dartmouth, Team 4-7, Catania Fall 2016 Member of UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 225
