Magellan RoadMate 5236T-LM Display Screen Replacement
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: step 1, image 1 of 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: step 1, image 2 of 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: step 1, image 3 of 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: step 2, image 1 of 3 Magellan RoadMate 5236T-LM Display Screen Replacement: step 2, image 2 of 3 Magellan RoadMate 5236T-LM Display Screen Replacement: step 2, image 3 of 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: step 3, image 1 of 2 Magellan RoadMate 5236T-LM Display Screen Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: step 4, image 1 of 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: step 4, image 2 of 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: step 4, image 3 of 3
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
2 other people completed this guide.
Megan Scribner
315 Reputation
2 Guides authored
UMass Dartmouth, Team 4-7, Catania Fall 2016 Member of UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 Members
5 Guides authored
One Comment
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 586
