Magellan RoadMate 5250T-LM Battery Replacement
  1. Magellan RoadMate 5250T-LM Battery Replacement, Battery: step 1, image 1 of 2 Magellan RoadMate 5250T-LM Battery Replacement, Battery: step 1, image 2 of 2
    • Remove all four 5 mm screws from the back of the device using a Phillips Head screwdriver size 000.
  2. Magellan RoadMate 5250T-LM Battery Replacement: step 2, image 1 of 2 Magellan RoadMate 5250T-LM Battery Replacement: step 2, image 2 of 2
    • Open the casing of the device using a plastic opening tool.
  3. Magellan RoadMate 5250T-LM Battery Replacement: step 3, image 1 of 2 Magellan RoadMate 5250T-LM Battery Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the tape covering the display connector on top of the motherboard.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Battery Replacement: step 4, image 1 of 2 Magellan RoadMate 5250T-LM Battery Replacement: step 4, image 2 of 2
    • Pry off the original battery using a spudger to break the adhesive that connects the battery to the back casing.
  5. Magellan RoadMate 5250T-LM Battery Replacement: step 5, image 1 of 2 Magellan RoadMate 5250T-LM Battery Replacement: step 5, image 2 of 2
    • Remove the motherboard from the device by unscrewing all three 4 mm screws that are connecting it to the casing with a Phillips Head screwdriver size 000.
  6. Magellan RoadMate 5250T-LM Battery Replacement: step 6, image 1 of 1
    • Disconnect the original battery from the motherboard by desoldering all three wires that attach it to the motherboard.
    • Click here to refer to iFixit's soldering technique guide for this step.
3 other people completed this guide.
Amanda
179 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 996
