Magellan RoadMate 5250T-LM Screen Replacement
  1. Magellan RoadMate 5250T-LM Screen Replacement, Screen: step 1, image 1 of 2 Magellan RoadMate 5250T-LM Screen Replacement, Screen: step 1, image 2 of 2
    • Holding the device in place, remove all four 5 mm screws from the back of the device using a Philips Head #000 screwdriver.
    • Place screws aside. Make sure they are easily accessible for reassembling the device.
  2. Magellan RoadMate 5250T-LM Screen Replacement: step 2, image 1 of 2 Magellan RoadMate 5250T-LM Screen Replacement: step 2, image 2 of 2
    • Lift the back cover using a spudger.
    • Remove back cover slowly and carefully to prevent damage.
  3. Magellan RoadMate 5250T-LM Screen Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Peel back the tape securing the display connector to the motherboard.
    • To ensure proper reassembly, do not remove or fold edges of tape.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Screen Replacement: step 4, image 1 of 2 Magellan RoadMate 5250T-LM Screen Replacement: step 4, image 2 of 2
    • Undo the four clamps holding down the display.
    • Remove the display from the front cover.
Jaimee Mound
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 353
