Magellan Roadmate 9055-LM Back Panel Disassembly
  1. Magellan Roadmate 9055-LM Back Panel Disassembly, Magellan Roadmate 9055-LM Back Panel Disassembly: step 1, image 1 of 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Back Panel Disassembly: step 2, image 1 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 2, image 2 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 2, image 3 of 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Back Panel Disassembly: step 3, image 1 of 2 Magellan Roadmate 9055-LM Back Panel Disassembly: step 3, image 2 of 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Back Panel Disassembly: step 4, image 1 of 2 Magellan Roadmate 9055-LM Back Panel Disassembly: step 4, image 2 of 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Back Panel Disassembly: step 5, image 1 of 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Back Panel Disassembly: step 6, image 1 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 6, image 2 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 6, image 3 of 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Back Panel Disassembly: step 7, image 1 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 7, image 2 of 3 Magellan Roadmate 9055-LM Back Panel Disassembly: step 7, image 3 of 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Back Panel Disassembly: step 8, image 1 of 1
    • Place the back panel gently on the table.
YuChe Chang
202 Reputation
2 Guides authored
UMass Dartmouth, Team 1-5, Catania Fall 2016 Member of UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 214
