Magic Bullet MB1001B Power Cord Replacement
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: step 1, image 1 of 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: step 2, image 1 of 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: step 3, image 1 of 1
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: step 4, image 1 of 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: step 5, image 1 of 1
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: step 6, image 1 of 1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: step 7, image 1 of 1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
2 other people completed this guide.
Bridget Carr
266 Reputation
1 Guide authored
Cal Poly, Team 12-13, Maness Fall 2015 Member of Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Members
8 Guides authored
2 Guide Comments
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Reply
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 24
All Time: 2,755
