Magic Bullet NutriBullet Base Replacement
  1. Magic Bullet NutriBullet Base Replacement, Base: step 1, image 1 of 1
    • Unplug the device from the wall and turn the powerbase upside down.
  2. Magic Bullet NutriBullet Base Replacement: step 2, image 1 of 2 Magic Bullet NutriBullet Base Replacement: step 2, image 2 of 2
    • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
  3. Magic Bullet NutriBullet Base Replacement: step 3, image 1 of 1
    • Once the screws are removed, use slight tension to pull the plastic base up.
    • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
3 other people completed this guide.
Angela Wong
1,156 Reputation
3 Guides authored
Cal Poly, Team 19-8, Maness Winter 2015 Member of Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Members
13 Guides authored
3 Guide Comments
So far it was easy! Yeah!
Elaine - Reply
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Reply
Where can you buy the base to replace?
Anne-Christine von Wetter - Reply
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 35
All Time: 10,411
