Magic Bullet NutriBullet Pro Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Magic Bullet NutriBullet Pro Disassembly, Magic Bullet NutriBullet Pro Disassembly: step 1, image 1 of 3 Magic Bullet NutriBullet Pro Disassembly, Magic Bullet NutriBullet Pro Disassembly: step 1, image 2 of 3 Magic Bullet NutriBullet Pro Disassembly, Magic Bullet NutriBullet Pro Disassembly: step 1, image 3 of 3
    • To start the disassembly of the Magic Bullet NutriBullet Pro you will begin from the bottom.
    • Flip the device over to the bottom.
    • Unscrew the four 1 cm screws using #2 Phillips Head Screwdriver.
    • Remove the loose bottom portion of the device by pulling up from the bottom.
  2. Magic Bullet NutriBullet Pro Disassembly: step 2, image 1 of 2 Magic Bullet NutriBullet Pro Disassembly: step 2, image 2 of 2
    • Unscrew the two 1 cm screws holding down the power cord using the #2 Phillips Head Screwdriver.
  3. Magic Bullet NutriBullet Pro Disassembly: step 3, image 1 of 3 Magic Bullet NutriBullet Pro Disassembly: step 3, image 2 of 3 Magic Bullet NutriBullet Pro Disassembly: step 3, image 3 of 3
    • Unscrew the three 1 cm screws on the device circled on the screws pictures using the #1 Philips Head Screwdriver.
    • Lift off the grey plastic piece off.
    • Slide off the silver metal piece.
  4. Magic Bullet NutriBullet Pro Disassembly: step 4, image 1 of 2 Magic Bullet NutriBullet Pro Disassembly: step 4, image 2 of 2
    • Flip the device over.
    • Remove the three rubber seals covering the screws by pulling the components upward with the tweezer.
    • Unscrew the three 16 mm screws using the #2 Phillips Head Screwdriver.
  5. Magic Bullet NutriBullet Pro Disassembly: step 5, image 1 of 2 Magic Bullet NutriBullet Pro Disassembly: step 5, image 2 of 2
    • Pull off the casing from the device.
Finish Line
2 other people completed this guide.
Brett Crews
173 Reputation
1 Guide authored
Cal Poly, Team 18-4, Forte Fall 2016 Member of Cal Poly, Team 18-4, Forte Fall 2016
CPSU-FORTE-F16S18G4
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 837
