Magic Trackpad Rubber Replacement/Reinsertion
  1. Magic Trackpad Rubber Replacement/Reinsertion, Rubber Feet: step 1, image 1 of 2 Magic Trackpad Rubber Replacement/Reinsertion, Rubber Feet: step 1, image 2 of 2
    • Unscrew the battery door by turning the screw counter-clockwise with a flat edge screwdriver, coin, plastic opening tool, or fingernail.
  2. Magic Trackpad Rubber Replacement/Reinsertion: step 2, image 1 of 3 Magic Trackpad Rubber Replacement/Reinsertion: step 2, image 2 of 3 Magic Trackpad Rubber Replacement/Reinsertion: step 2, image 3 of 3
    • The rubber buffer consists of two parts: a rigid part made ​​of plastic and the sheath, which is made ​​of rubber.
    • The shape of the foot may not be perfectly spherical, as in the photo. This can occur when a portion of the rubber flap has come out of the notch. When you put it back in, it will become spherical again.
  3. Magic Trackpad Rubber Replacement/Reinsertion: step 3, image 1 of 3 Magic Trackpad Rubber Replacement/Reinsertion: step 3, image 2 of 3 Magic Trackpad Rubber Replacement/Reinsertion: step 3, image 3 of 3
    • Using a spudger or small flathead screwdriver, gently break the seal between the white plastic backing and the metal top near the missing foot opening.
    • Pry up the corner slightly to allow the foot to be replaced.
    • Place the rubber foot back in place.
    • Squeeze closed the backing and metal top (it will snap into place).
    • Click on trackpad to test.
    • Insert the battery and screw the battery cover closed.
    • A foot may again dislodge, for example when you inadvertently move a sheet of paper under the trackpad. Repeat steps as needed to replace.
  4. Magic Trackpad Rubber Replacement/Reinsertion: step 4, image 1 of 3 Magic Trackpad Rubber Replacement/Reinsertion: step 4, image 2 of 3 Magic Trackpad Rubber Replacement/Reinsertion: step 4, image 3 of 3
    • If you want to remove the plastic cover completely, it is better to open it starting from the top.
    • Opening from the top will reduce the risk of breaking any of the clips at the bottom.
    • The cover is attached to the trackpad through rubber glue on the plastic grid and four clips on the bottom.
    • Take your time to slowly open the plastic cover from the top side.
Finish Line
178 other people completed this guide.
revher
4,130 Reputation
2 Guides authored
67 Guide Comments
where can i buy the plastic feet?????
Lorraine Hughes - Reply
Yes. Where can I buy the rubber feet?
Rick Sciranko -
I bought mine off Ali Express. There’s quite a few stores on there that sell them. Here’s the one I bought from.
James Sanday -
Found this guide confusing. Here's what worked for me:
1. Place the tip of a butter knife inside the hole and gently lift the plastic high enough to place the tip of another butter knife on the side and hold the plastic up.
2. Remove the first butter knife from the hole. Gently raise the plastic with the second butter knife high enough to slide the foot underneath.
3. Use the first butter knife to slide/rotate the foot into place
Jeremy Johnson - Reply
The butter knife technique worked for me! I just cracked open the bottom edge of where my little rubber foot had fallen out. (Somehow the plastic was still in there so I was able to stick the foot back in and it works!)
Frances Darwin -
Past 24 Hours: 19
Past 7 Days: 89
Past 30 Days: 466
All Time: 111,724
