Magnavox MWD200F Disk Drive Replacement
  1. Magnavox MWD200F Disk Drive Replacement, Faceplate: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. Magnavox MWD200F Disk Drive Replacement: step 2, image 1 of 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. Magnavox MWD200F Disk Drive Replacement: step 3, image 1 of 1
    • Unclip the three latches on the bottom of the device.
  4. Magnavox MWD200F Disk Drive Replacement: step 4, image 1 of 1
    • Pull the faceplate off.
  5. Magnavox MWD200F Disk Drive Replacement, Disk Drive: step 5, image 1 of 2 Magnavox MWD200F Disk Drive Replacement, Disk Drive: step 5, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. Magnavox MWD200F Disk Drive Replacement: step 6, image 1 of 2 Magnavox MWD200F Disk Drive Replacement: step 6, image 2 of 2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. Magnavox MWD200F Disk Drive Replacement: step 7, image 1 of 2 Magnavox MWD200F Disk Drive Replacement: step 7, image 2 of 2
    • Pull out the silver security bar and set aside.
  8. Magnavox MWD200F Disk Drive Replacement: step 8, image 1 of 1
    • Take out the two screws on either side of the green circuit board.
  9. Magnavox MWD200F Disk Drive Replacement: step 9, image 1 of 2 Magnavox MWD200F Disk Drive Replacement: step 9, image 2 of 2
    • Carefully lift the board just enough to remove the disk drive.
  10. Magnavox MWD200F Disk Drive Replacement: step 10, image 1 of 3 Magnavox MWD200F Disk Drive Replacement: step 10, image 2 of 3 Magnavox MWD200F Disk Drive Replacement: step 10, image 3 of 3
    • Remove the two screws at the back of the disk drive.
  11. Magnavox MWD200F Disk Drive Replacement: step 11, image 1 of 2 Magnavox MWD200F Disk Drive Replacement: step 11, image 2 of 2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
Taryn
109 Reputation
4 Guides authored
One Comment
This also works with the SV2000 WV205 dvd player.
-Franklin
Franklin Piper - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,527
