Maisto Rock Crawler Front Axle Replacement
  1. Maisto Rock Crawler Front Axle  Replacement, Front Axle: step 1, image 1 of 2 Maisto Rock Crawler Front Axle  Replacement, Front Axle: step 1, image 2 of 2
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Maisto Rock Crawler Front Axle  Replacement: step 2, image 1 of 2 Maisto Rock Crawler Front Axle  Replacement: step 2, image 2 of 2
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Front Axle  Replacement: step 3, image 1 of 1
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. Maisto Rock Crawler Front Axle  Replacement: step 4, image 1 of 1
    • After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Philips screws that hold the side circuit board in.
  5. Maisto Rock Crawler Front Axle  Replacement: step 5, image 1 of 1
    • Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
  6. Maisto Rock Crawler Front Axle  Replacement: step 6, image 1 of 1
    • Flip the R/C truck back over.
    • Remember which wire is connected at which pin before desoldering.
    • Desolder the 4 wires connected from the front axle to the circuit board.
  7. Maisto Rock Crawler Front Axle  Replacement: step 7, image 1 of 1
    • You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
kevin
874 Reputation
6 Guides authored
USF Tampa, Team 1-2, Sullivan Spring 2016 Member of USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 35
All Time: 5,300
