Makita DT01 Trigger Switch Replacement
Victoria Scira
Victoria Scira and 3 other contributors
Last updated on May 7, 2024
10 minutes
Moderate
Introduction
Go to step 1
This will teach you how to replace your trigger switch on your Makita DT01 drill.
  1. Makita DT01 Trigger Switch Replacement, Battery: step 1, image 1 of 3 Makita DT01 Trigger Switch Replacement, Battery: step 1, image 2 of 3 Makita DT01 Trigger Switch Replacement, Battery: step 1, image 3 of 3
    • Lay the device down on its side.
  2. Makita DT01 Trigger Switch Replacement: step 2, image 1 of 1
    • Pinch the indents on both sides of the battery.
  3. Makita DT01 Trigger Switch Replacement: step 3, image 1 of 1
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
  4. Makita DT01 Trigger Switch Replacement, Trigger Switch: step 4, image 1 of 1
    • Unscrew all six 15mm screws with a JIS1 screwdriver bit.
  5. Makita DT01 Trigger Switch Replacement: step 5, image 1 of 1
    • Remove the top of the plastic drill case
  6. Makita DT01 Trigger Switch Replacement: step 6, image 1 of 1
    • Remove the bottom of the plastic drill case
  7. Makita DT01 Trigger Switch Replacement: step 7, image 1 of 1
    Tool used on this step:
    • Use your tweezers to remove the black wire from the motor
  8. Makita DT01 Trigger Switch Replacement: step 8, image 1 of 1
    • Use your tweezers to remove the red wire from the motor
  9. Makita DT01 Trigger Switch Replacement: step 9, image 1 of 1
    • Your trigger switch should now be removed from your motor
  10. Makita DT01 Trigger Switch Replacement: step 10, image 1 of 1
    • Use your tweezers to remove the red and black wires from the two-pronged plug
  11. Makita DT01 Trigger Switch Replacement: step 11, image 1 of 1
    • Your trigger switch is now detached from the device
Victoria Scira
226 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 707
