Makita GA4030K Armature Replacement
  1. Makita GA4030K Armature Replacement, Disk Cover: step 1, image 1 of 1
    • Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
  2. Makita GA4030K Armature Replacement: step 2, image 1 of 1
    • Unscrew the handle unit until it is removed completely.
  3. Makita GA4030K Armature Replacement: step 3, image 1 of 2 Makita GA4030K Armature Replacement: step 3, image 2 of 2
    • Hold the black switch located on the front casing.
    • Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
    • Once loose, remove the silver disk and/or your grinding disk.
  4. Makita GA4030K Armature Replacement: step 4, image 1 of 2 Makita GA4030K Armature Replacement: step 4, image 2 of 2
    • Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
    • Remove the cover by lining up the knob on the cover with the notch in face plate.
  5. Makita GA4030K Armature Replacement, Back Cover: step 5, image 1 of 2 Makita GA4030K Armature Replacement, Back Cover: step 5, image 2 of 2
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  6. Makita GA4030K Armature Replacement: step 6, image 1 of 1
    • Slide the back cover down the power cable.
  7. Makita GA4030K Armature Replacement, Armature: step 7, image 1 of 2 Makita GA4030K Armature Replacement, Armature: step 7, image 2 of 2
    • Use a spudger to gently move the brush holder coil to the side.
    • There are two brushes that are secured by two separate brush holders, one on each side.
  8. Makita GA4030K Armature Replacement: step 8, image 1 of 2 Makita GA4030K Armature Replacement: step 8, image 2 of 2
    • Using a metal spudger, remove both carbon brushes (one on each side) by their copper cabling.
  9. Makita GA4030K Armature Replacement: step 9, image 1 of 3 Makita GA4030K Armature Replacement: step 9, image 2 of 3 Makita GA4030K Armature Replacement: step 9, image 3 of 3
    • Use a Phillips #2 screwdriver to remove the four 20 mm tapping screws that hold the armature assembly in place.
    • Remove the armature assembly
  10. Makita GA4030K Armature Replacement: step 10, image 1 of 2 Makita GA4030K Armature Replacement: step 10, image 2 of 2
    • Unscrew the four 10 mm tapping screws holding the faceplate using a Phillips #02 screwdriver.
    • Remove the faceplate.
  11. Makita GA4030K Armature Replacement: step 11, image 1 of 2 Makita GA4030K Armature Replacement: step 11, image 2 of 2
    • Hold the highlighted nut with a size 10 wrench. Unscrew by turning the armature and holding the nut in place.
    • The nut may be difficult to remove.
  12. Makita GA4030K Armature Replacement: step 12, image 1 of 1
    • Remove the armature.
5 other people completed this guide.
Laura Ann Jagels
490 Reputation
3 Guides authored
Cal Poly, Team 12-5, Lancaster Spring 2015 Member of Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 25
All Time: 3,451
