Makita GA4030K Carbon Brush Replacement
  1. Makita GA4030K Carbon Brush Replacement, Back Cover: step 1, image 1 of 2 Makita GA4030K Carbon Brush Replacement, Back Cover: step 1, image 2 of 2
    • Unscrew the 20 mm tapping screw using a Philips #02 screwdriver.
  2. Makita GA4030K Carbon Brush Replacement: step 2, image 1 of 1
    • Slide the back cover down the power cable.
  3. Makita GA4030K Carbon Brush Replacement, Carbon Brushes: step 3, image 1 of 2 Makita GA4030K Carbon Brush Replacement, Carbon Brushes: step 3, image 2 of 2
    • Use a spudger to move the springs (holding the brushes) to the side.
    • There are two brushes, one on each side.
  4. Makita GA4030K Carbon Brush Replacement: step 4, image 1 of 2 Makita GA4030K Carbon Brush Replacement: step 4, image 2 of 2
    • Use needle nose pliers to gently pull out the carbon brushes by their crimped connectors.
3 other people completed this guide.
Nyssa Backes
467 Reputation
3 Guides authored
Cal Poly, Team 12-5, Lancaster Spring 2015 Member of Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 27
All Time: 4,032
