Makita Jack Hammer HM1203C 2010 Power Cord Replacement
  1. Makita Jack Hammer HM1203C 2010 Power Cord Replacement, Remove the handle cover: step 1, image 1 of 1
    • Make sure the hammer is disconnected from power before beginning any repair.
    • Use a Phillips #2 screwdriver to remove two screws securing the handle cover.
  2. Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 2, image 1 of 2 Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 2, image 2 of 2
    • Swing the bottom of the handle cover away from the hammer, then pull the cover down, toward the power cord, to remove it.
  3. Makita Jack Hammer HM1203C 2010 Power Cord Replacement, Remove the power cord: step 3, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the screw securing the power cord bracket.
  4. Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 4, image 1 of 2 Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 4, image 2 of 2
    • Lift the bottom edge of the bracket away from the hammer slightly, then pull down to remove it.
    • During reassembly, make sure the top hooked part of the bracket is inserted properly into its slot.
  5. Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 5, image 1 of 1
    Tool used on this step:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Buy
    • Use a 2.5 mm flathead screwdriver to loosen the two set screws holding in the power cord wires.
  6. Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 6, image 1 of 3 Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 6, image 2 of 3 Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 6, image 3 of 3
    • Remove the power cord.
  7. Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 7, image 1 of 2 Makita Jack Hammer HM1203C 2010 Power Cord Replacement: step 7, image 2 of 2
    • Slide the power cord guard off of the power cord.
    • During reassembly, install this guard on the new power cord.
  8. Makita Jack Hammer HM1203C 2010 Power Cord Replacement, Prepare the new power cord: step 8, image 1 of 2 Makita Jack Hammer HM1203C 2010 Power Cord Replacement, Prepare the new power cord: step 8, image 2 of 2
    • Use 10 gauge wire strippers to strip about 1/8 inch of insulation off of each wire of the new power cord.
3 other people completed this guide.
Adam O'Camb
208,955 Reputation
416 Guides authored
One Comment
What does the flashing red indicator light indicate specifically? The green light is on but the red light underneath is also flashing.
MARK - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,801
